my adventures in painting the car thread, DONE! Some final thoughts... |
914 RZ-1 |
Jul 11 2018, 09:55 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting: After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel: Option 1: I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done. Option 2: I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray. Option 3: I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on. |
914 RZ-1 |
Jul 12 2018, 06:53 PM
Thanks to all. I appreciate you input.
I'm using single stage paint by R-M. Mix ratio: 4:1:1 (paint, reducer, hardener). It was in the 80's when I painted. I probably should have used reducer for higher temps. I painted the car body and used high temp reducer and it looks much better. Gun is set at about 10-15 psi where the airline enters the gun. I can't see the readout very well anymore because the plastic cover on the gauge got fogged up when I tried to clean it with acetone. I may have the paint amount too high as well (2.5 turns in from when the threads engage), so I'll try adjusting that. I practiced, but it was a few months ago, so the conditions are different now. I only have 1.5 quarts of paint left. I could get more but I'm concerned about matching batches. |
Lo-Fi Version | Time is now: 2nd May 2024 - 06:30 AM |
