my adventures in painting the car thread, DONE! Some final thoughts... |
914 RZ-1 |
Jul 11 2018, 09:55 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting: After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel: Option 1: I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done. Option 2: I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray. Option 3: I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on. |
914 RZ-1 |
Jul 13 2018, 12:32 PM
Here is the result after wet-sanding with 800-1000-1500 then polishing with V32 and then V36 polish (Chemical Guys).
They are still some depressions from the orange peel that look like dots and there are some scratches. I thought I got these out; they appeared after I polished. I'm thinking I need to paint one, maybe two, more coats so I have enough material to sand off. Should I use a machine sander (DA), or keep doing it by hand? |
mb911 |
Jul 13 2018, 03:20 PM
914 Guru Group: Members Posts: 6,818 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Here is the result after wet-sanding with 800-1000-1500 then polishing with V32 and then V36 polish (Chemical Guys). They are still some depressions from the orange peel that look like dots and there are some scratches. I thought I got these out; they appeared after I polished. I'm thinking I need to paint one, maybe two, more coats so I have enough material to sand off. Should I use a machine sander (DA), or keep doing it by hand? I would wet sand with 400, clean, prime and repaint. |
mepstein |
Jul 13 2018, 03:30 PM
914-6 GT in waiting Group: Members Posts: 19,251 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Here is the result after wet-sanding with 800-1000-1500 then polishing with V32 and then V36 polish (Chemical Guys). They are still some depressions from the orange peel that look like dots and there are some scratches. I thought I got these out; they appeared after I polished. I'm thinking I need to paint one, maybe two, more coats so I have enough material to sand off. Should I use a machine sander (DA), or keep doing it by hand? I would wet sand with 400, clean, prime and repaint. (IMG:style_emoticons/default/agree.gif) that’s what our shop would do. You don’t want to machine sand unless you really know what you are doing. |
Lo-Fi Version | Time is now: 2nd May 2024 - 12:56 AM |
