my adventures in painting the car thread, DONE! Some final thoughts... |
914 RZ-1 |
Jul 11 2018, 09:55 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting: After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel: Option 1: I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done. Option 2: I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray. Option 3: I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on. |
aggiezig |
Aug 2 2018, 08:39 PM
Porsche Wannabe Group: Members Posts: 319 Joined: 13-January 16 From: Los Angeles, CA Member No.: 19,557 Region Association: Southern California |
I think that with enough trial/error & practice you can do a pretty bang up job yourself. You just have to be realistic with your expectations and also be willing to work at it for hours and hours. I think all said and done I will have between $2,500 and $3,000 invested in my paint job. That includes paint guns, sanders, primers, good quality paint, undercoating, fillers, supplies, etc.
Prior to my current project, I had zero experience. I am learning as I go and pleased with my results. This is using PPG DCC Concept single stage acrylic urethane in Mexico Blue. After a cut with 2000 and compound with M105. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-19557-1533263956.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-19557-1533263956.2.jpg) |
914 RZ-1 |
Aug 8 2018, 12:18 PM
Nice job! Yeah, it's taking me lots of practice. I'm using the hoods to dial it in since they are easy to sand and re-paint.
I think that with enough trial/error & practice you can do a pretty bang up job yourself. You just have to be realistic with your expectations and also be willing to work at it for hours and hours. I think all said and done I will have between $2,500 and $3,000 invested in my paint job. That includes paint guns, sanders, primers, good quality paint, undercoating, fillers, supplies, etc. Prior to my current project, I had zero experience. I am learning as I go and pleased with my results. This is using PPG DCC Concept single stage acrylic urethane in Mexico Blue. After a cut with 2000 and compound with M105. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-19557-1533263956.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-19557-1533263956.2.jpg) |
Lo-Fi Version | Time is now: 2nd May 2024 - 04:51 AM |
