my adventures in painting the car thread, DONE! Some final thoughts... |
914 RZ-1 |
Jul 11 2018, 09:55 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting: After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel: Option 1: I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done. Option 2: I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray. Option 3: I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on. |
914 RZ-1 |
Aug 8 2018, 12:15 PM
So I got the suggested filter:
https://www.harborfreight.com/inline-desicc...lter-68215.html However, it doesn't seem to allow enough pressure thru. I have the hose going into the filter, then the pressure regulator, then the gun. With the pumpkin filter and the gauge set at 30psi, I get plenty of air. But, with the filter above and the gauge set at 30psi, I get far less air, the spray pattern is smaller. I tried it with two different air pressure gauges. Not sure what's causing this. None of my usual sources addresses this. I painted the hoods and am still getting a bit of orange peel. The gun also sprays intermittently, but only when painting; it works fine when I spray acetone thru it. |
Andyrew |
Aug 8 2018, 12:42 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
So I got the suggested filter: https://www.harborfreight.com/inline-desicc...lter-68215.html However, it doesn't seem to allow enough pressure thru. I have the hose going into the filter, then the pressure regulator, then the gun. With the pumpkin filter and the gauge set at 30psi, I get plenty of air. But, with the filter above and the gauge set at 30psi, I get far less air, the spray pattern is smaller. I tried it with two different air pressure gauges. Not sure what's causing this. None of my usual sources addresses this. I painted the hoods and am still getting a bit of orange peel. The gun also sprays intermittently, but only when painting; it works fine when I spray acetone thru it. You need to put your regulator after the filter. Your air tank should be at say 90psi. The desiccant filter certainly takes a bit more air pressure to push through but it shouldnt be that bad. |
914 RZ-1 |
Aug 8 2018, 05:57 PM
The desiccant filter certainly takes a bit more air pressure to push through but it shouldnt be that bad. I did that: air hose from tank>filter>regulator>gun. Tank is set about 80-90 psi. The difference is really noticable. I thought it odd that the gauge read the same with both filters, but the air coming out of the gun is clearly different. I tried two different gauges, too. The filter had two caps, which I took out. Did I miss something else that could be blocking airflow? |
Lo-Fi Version | Time is now: 2nd May 2024 - 05:55 AM |
