my adventures in painting the car thread, DONE! Some final thoughts... |
914 RZ-1 |
Jul 11 2018, 09:55 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting: After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel: Option 1: I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done. Option 2: I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray. Option 3: I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on. |
Andyrew |
Aug 9 2018, 02:03 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Note. Spray the body side in one go, Not panel by panel as shown. Walk the body.
This was only the 2nd car I sprayed at the time and I was still learning. Doing it the method shown will cause for runs near the body seams. |
914 RZ-1 |
Aug 9 2018, 05:24 PM
Yeah, that's what I'm doing. I actually have the doors off, so it's not really an issue. At this point, I'm trying to dial in the technique on the hoods so I can spray the body one more time and be done.
When I'm done, this car will have LOTS of coats of paint. Note. Spray the body side in one go, Not panel by panel as shown. Walk the body. This was only the 2nd car I sprayed at the time and I was still learning. Doing it the method shown will cause for runs near the body seams. |
Lo-Fi Version | Time is now: 2nd May 2024 - 12:06 AM |
