my adventures in painting the car thread, DONE! Some final thoughts... |
914 RZ-1 |
Jul 11 2018, 09:55 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting: After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel: Option 1: I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done. Option 2: I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray. Option 3: I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on. |
dakotaewing |
Aug 19 2018, 06:01 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
Please show pictures of your compressor, hoses and filter set up, and Gun.
Most likely you suffer from a variety of issues contributing to the problem, rather than just one. It all starts at the compressor, amount of air volume, and how hard the compressor has to work to keep up. It then goes to the hoses, filter and gun. Then you need to take into account the temp and humidity. I have never sprayed anything but primer, but I would never consider spraying my car in the current Texas heat. You have so many things going against you as a newbie (painter), that I would want to spray my car when the temp is as close to 70 degrees as possible. For me that means October or mid March. |
914 RZ-1 |
Aug 19 2018, 06:31 PM
Please show pictures of your compressor, hoses and filter set up, and Gun. Most likely you suffer from a variety of issues contributing to the problem, rather than just one. It all starts at the compressor, amount of air volume, and how hard the compressor has to work to keep up. It then goes to the hoses, filter and gun. Then you need to take into account the temp and humidity. I have never sprayed anything but primer, but I would never consider spraying my car in the current Texas heat. You have so many things going against you as a newbie (painter), that I would want to spray my car when the temp is as close to 70 degrees as possible. For me that means October or mid March. For your viewing pleasure: The second hose is used for cleaning the gun outside. |
Lo-Fi Version | Time is now: 2nd May 2024 - 04:12 AM |
