my adventures in painting the car thread, DONE! Some final thoughts... |
914 RZ-1 |
Jul 11 2018, 09:55 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting: After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel: Option 1: I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done. Option 2: I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray. Option 3: I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on. |
Andyrew |
Aug 19 2018, 06:55 PM
Ya, I put 7 coats on mine when I did it. Took 3 for full coverage, so I had 4 to work with.
If your getting down to the primer then my suggestion is adjust the thickness. Orange peal is easier to work with than runs, but its OK if you only have a run or two to deal with. I would say add another 25% reducer to your paint. Give it less flash time by a couple minutes if you can and try again on a vertical panel. I think your really close. Some orange peal is inevitable. |
Lo-Fi Version | Time is now: 2nd May 2024 - 01:23 AM |
