my adventures in painting the car thread, DONE! Some final thoughts... |
914 RZ-1 |
Jul 11 2018, 09:55 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting: After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel: Option 1: I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done. Option 2: I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray. Option 3: I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on. |
ConeDodger |
Aug 26 2018, 04:03 PM
Apex killer! Group: Members Posts: 23,573 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Get rid of that first length of hose of the compressor. That curly-Q shit is just asking for condensation. Have a length of hose just long enough to get from the compressor to the dryer manifold made at AirGas. Use a dryer at the gun if you’re not. Avoid low spots in your hose.
Wetter. You’re avoiding runs, yes but you have to lay down some paint. I’ve watched the Eastwood Kevin Tetz videos a thousand times. Best I’ve ever seen. |
Lo-Fi Version | Time is now: 1st May 2024 - 10:52 PM |
