my adventures in painting the car thread, DONE! Some final thoughts... |
914 RZ-1 |
Jul 11 2018, 09:55 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting: After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel: Option 1: I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done. Option 2: I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray. Option 3: I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on. |
IronHillRestorations |
Aug 26 2018, 04:39 PM
I. I. R. C. Group: Members Posts: 6,715 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I'll 2nd Ben's opinion. I think you probably are using the wrong reducer, so your paint isn't laying down well, you're gun pressure/paint flow isn't correct, and your technique isn't there yet. Additionally you do probably have water in your air supply problems too.
If learning how to paint your car is part of the process, then you need enough paint supplies and practice surfaces to develop your skills. I see this with new welders. A guy (who's never welded before) goes and buys a new MIG welder (to make it worse it's often flux core), makes three practice beads on 1/4" angle iron, and heads off to fix his hell hole. Practice does make perfect, and don't practice on a critical surface. |
Lo-Fi Version | Time is now: 2nd May 2024 - 12:39 AM |
