Any tricks to replacing the rear flex brake lines? |
andreic |
Jul 12 2018, 06:04 PM
Member Group: Members Posts: 172 Joined: 21-December 15 From: Madison, WI Member No.: 19,479 Region Association: Upper MidWest |
The title says it all. One of my rear flex lines is leaking, and I need to replace it. I looked at it from underneath the car, and it looks like the top of the line will be a bear to unscrew from the rigid line, and also to remove the clip that holds it, the space is very tight.
Does anyone have any tricks to making the job easier? Thanks. |
Jul 12 2018, 06:19 PM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I think I clipped the rubber line near the fitting and then used a socket. Used a screw driver to pry the clip out. Or vise grips, cant remember. Its good to replace all the lines if you cant remember when they were last done.
TravisNeff |
Jul 12 2018, 07:19 PM
bbrock |
Jul 12 2018, 07:23 PM
I think I clipped the rubber line near the fitting and then used a socket. Used a screw driver to pry the clip out. Or vise grips, cant remember. Its good to replace all the lines if you cant remember when they were last done. That's the method I used to remove my flex lines that were heavily corroded from sitting outside for 30 years and it worked great. I did soak mine down with PB Blaster for a couple days before wrenching. Not sure if there is contamination risk from that, but I'm replacing my hard lines too so it didn't matter. |
stinkindiesel |
Jul 13 2018, 12:50 PM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
I don't recall any particular issues. Yes, it's tight, but still possible to get a couple of end wrenches in there. Just be sure to keep a wrench on the hard line side as well so you don't twist the hard line while trying to remove the soft line. If I remember right, it was easier to remove the retaining clip first so you can pull the line out a little to give you more room. End wrench (or better yet, a flare nut wrench) on each side, and then squeeze the two wrench handles together.
Gary |
dr914@autoatlanta.com |
Jul 13 2018, 02:35 PM
914 Guru Group: Members Posts: 7,833 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
or bend the mounting tab
The title says it all. One of my rear flex lines is leaking, and I need to replace it. I looked at it from underneath the car, and it looks like the top of the line will be a bear to unscrew from the rigid line, and also to remove the clip that holds it, the space is very tight. Does anyone have any tricks to making the job easier? Thanks. |
Jul 13 2018, 05:22 PM
There are people who have waited until the engine was out so they had better access. Some have also talked about working through some holes in the engine shelf or the engine tin, I think? (Sorry, I don't remember.)
--DD |
worn |
Jul 13 2018, 05:56 PM
can't remember Group: Members Posts: 3,150 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
The title says it all. One of my rear flex lines is leaking, and I need to replace it. I looked at it from underneath the car, and it looks like the top of the line will be a bear to unscrew from the rigid line, and also to remove the clip that holds it, the space is very tight. Does anyone have any tricks to making the job easier? Thanks. If you don’t already have them get some line wrenches. The reduction in rounded over fittings will pay for the set. |
Jul 13 2018, 06:01 PM
The title says it all. One of my rear flex lines is leaking, and I need to replace it. I looked at it from underneath the car, and it looks like the top of the line will be a bear to unscrew from the rigid line, and also to remove the clip that holds it, the space is very tight. Does anyone have any tricks to making the job easier? Thanks. If you don’t already have them get some line wrenches. The reduction in rounded over fittings will pay for the set. (IMG:style_emoticons/default/agree.gif) my dad gave me a set that he never used. Worth ever penny he paid. (IMG:style_emoticons/default/biggrin.gif) |
jim_hoyland |
Jul 13 2018, 06:11 PM
Get that VIN ? Group: Members Posts: 9,272 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The title says it all. One of my rear flex lines is leaking, and I need to replace it. I looked at it from underneath the car, and it looks like the top of the line will be a bear to unscrew from the rigid line, and also to remove the clip that holds it, the space is very tight. Does anyone have any tricks to making the job easier? Thanks. If you don’t already have them get some line wrenches. The reduction in rounded over fittings will pay for the set. What sizes do we need ? |
IronHillRestorations |
Jul 13 2018, 06:26 PM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
You can get to it from the topside of the engine bay with a crowfoot (flare preferably) on several extensions through the drip tube hole. This is a Brad Mayeur trick.
ConeDodger |
Jul 13 2018, 06:47 PM
Apex killer! Group: Members Posts: 23,575 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Lots and lots of PB Blaster... (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 4th May 2024 - 07:38 PM |
