Windshield Washer Pressure Valve, Valve that regulates pressure from the tire not working |
ctc911ctc |
Jul 15 2018, 10:24 AM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Greeting,
I am resurrecting a barn find that has been in a garage since Reagan was in office. '74 2.0, with the exception of the Helatious Hell Hole, in pretty good shape. I am stumped with the valve that is within the filling opening of the Windshield washer reservoir. It will not allow any of the tire pressure into the reservoir.....I have tried to coax it into operation with extra pressure, etc. Has anyone ever fixed one of these? I know I can get a new one for 35.00, however, there just may be a quick fix within this knowledgeable forum! Thanks in Advance for any pointers. C |
914Sixer |
Jul 15 2018, 12:36 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Check valves are about $7 or less each. The best set up is one straight one at each nozel and one at the T.
As for the bottle the connection it is a straight tire air valve. Does you bottle have a leak and is the seal good. I am sure if you put a WTB there are lots of cheap replacements available. They rarely fail. Attached image(s) |
bbrock |
Jul 15 2018, 02:37 PM
Correct me if I'm wrong, but doesn't the check valve on the bottle also limit the amount of pressure that can be bled from the tire so you don't wind up with a flat spare just when you need it?
Lo-Fi Version | Time is now: 27th April 2024 - 06:22 PM |
