Electric Windshield Washer Conversion 914, Complete kit |
rothaus |
Jul 15 2018, 01:20 PM
Member Group: Members Posts: 119 Joined: 20-November 10 From: Virginia Member No.: 12,404 Region Association: None |
On the Porsche 914 the original windshield washer is operated by compressed air supplied from the Spare tire.
Here is the switch that replaces the original valve in the steering column. With this switch installed, an electrical washer pump can be operated with the wiper switch. (IMG:http://www.914world.com/bbs2/uploads_offsite/carmagic.us-12404-1531682421.1.jpg) I got some requests if it would be possible to have a complete kit available. So I put together a complete kit, and also have now options. It's not yet on the website, however here is the information with the options and prices. Option 1: Switch only - $15.00 PLUS $5 s/h Option 2: Relay kit only - $35.00 plus $6 s/h Option 3: Switch and relay kit - $50.00 plus $6 s/h Option 4: Option 3 plus pump - $72.00 plus $8 s/h The switch is pre-wired and includes the mounting plate and some washer for adjustment if needed. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-12404-1623100568.1.jpg) The relay kit includes all wires, a fuse, and connectors, shrink tubing, bolt to mount the relay, as well the disc for the filler cap. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-12404-1623100568.2.jpg) Here is the wire diagram which will also be included in the step by step instructions. (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-12404-1549839863.1.jpg) The switch can be ordered at http://carmagic.us/washer.html Cheers Engelbert |
DRPHIL914 |
Apr 25 2021, 04:53 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Ok, here is my recommended wire diagram for the washer switch installation. However, there are other ways to wire the switch. (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-12404-1549839863.1.jpg) Hope this will help. Thanks Engelbert since several other members are dealing with this issue again , i am bringing it up again to ask if this relay will work? only difference i see is it has a 87 & 87b. that and the 85&86 are unopposed positions. Attached thumbnail(s) |
rothaus |
Apr 26 2021, 05:26 AM
Ok, here is my recommended wire diagram for the washer switch installation. However, there are other ways to wire the switch. (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-12404-1549839863.1.jpg) Hope this will help. Thanks Engelbert since several other members are dealing with this issue again , i am bringing it up again to ask if this relay will work? only difference i see is it has a 87 & 87b. that and the 85&86 are unopposed positions. This is basically a Bosch type relay. 87a is normal activated. 87 is activated when the coil is energized. So 87a is not used. |
DRPHIL914 |
Apr 26 2021, 08:18 AM
Ok, here is my recommended wire diagram for the washer switch installation. However, there are other ways to wire the switch. (IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-12404-1549839863.1.jpg) Hope this will help. Thanks Engelbert since several other members are dealing with this issue again , i am bringing it up again to ask if this relay will work? only difference i see is it has a 87 & 87b. that and the 85&86 are unopposed positions. This is basically a Bosch type relay. 87a is normal activated. 87 is activated when the coil is energized. So 87a is not used. super thanks for the response, i am going to install this relay tonight! i should have a working washer pump soon! yay! when i go the car 12 years ago i had dry rotted water lines leaking, and i changed them out but still had issues, 2 years ago after paint and body , i put in the new lines and squirters with anticipation of getting a pump. just nice to. wrap up a few small details like this that didn’t get done at the time. |
Lo-Fi Version | Time is now: 18th May 2024 - 05:40 AM |
