Tow stuff |
Tow stuff |
hedfurst |
Jul 16 2018, 03:33 PM
Member Group: Members Posts: 99 Joined: 9-March 03 From: S. Mississippi Member No.: 406 |
(IMG:style_emoticons/default/welder.gif)
Weekend fun! |
hedfurst |
Jul 16 2018, 03:50 PM
Attached thumbnail(s) |
Mikey914 |
Jul 16 2018, 04:23 PM
The rubber man Group: Members Posts: 12,657 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Looks pkeanty sturdy, but you are limited by the substructure.
Theres not a lot of metal there. |
hedfurst |
Jul 18 2018, 11:15 AM
Looks pkeanty sturdy, but you are limited by the substructure. Theres not a lot of metal there. Cool thing is I have modified an aftermarket tow-piece to attach to the stock tow bolt receptacle. I’m pretty sure it will work. I’ve used the stock piece there back in the day (mid 70s ) and towed a VW beetle. My car is less than a ton and a dedicated tracker. |
Jul 18 2018, 12:08 PM
914-6 GT in waiting Group: Members Posts: 19,256 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I'm confused. Are you towing something or strapping down your car? I wouldn't use that location for either.
hedfurst |
Jul 18 2018, 12:56 PM
I'm confused. Are you towing something or strapping down your car? I wouldn't use that location for either. It’s a track car. Needs an obvious tow hook-up in case of a mechanical failure. Different story all together if there’s an accident! I have a completely different mechanism on the front. Attached thumbnail(s) |
Jul 18 2018, 02:35 PM
I'm confused. Are you towing something or strapping down your car? I wouldn't use that location for either. It’s a track car. Needs an obvious tow hook-up in case of a mechanical failure. Different story all together if there’s an accident! I have a completely different mechanism on the front. Ahhh, got it. |
Lo-Fi Version | Time is now: 7th May 2024 - 10:48 AM |
