WTB: 2.0 Cooling Tin and Runners |
BeatNavy |
Jul 18 2018, 06:45 AM
Looking for the left / right TOP cooling tin pieces (the big pieces) from a 2.0 that are in decent shape. Would prefer to not have to modify 1.7 pieces if possible. Also, 2.0 intake runners.
Shipping in this case to zip 49508. |
BeatNavy |
Jul 18 2018, 01:03 PM
Thanks, fellas. I'll wait to see what Kevin has, and then maybe circle back to Clay and/or Phil. Darn, A/C sure sounds nice right about now, but I'm not sure I'm ready to go that route on cutting up the other body parts. What part of the tin gets modified / cut for that?
Phil, couldn't tell if you do or don't have the parts (IMG:style_emoticons/default/biggrin.gif) Sounds like you're not sure? Thanks again, guys. |
ClayPerrine |
Jul 18 2018, 01:32 PM
Life's been good to me so far..... Group: Admin Posts: 15,469 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Darn, A/C sure sounds nice right about now, but I'm not sure I'm ready to go that route on cutting up the other body parts. What part of the tin gets modified / cut for that? Right front corner, where the accelerator cable hole is located. The compressor is below the battery tray. I use the compressor and mounts from ICEAC. It is designed for the type IV motor. To pull the motor, you take the compressor loose and set it in the battery tray. |
Lo-Fi Version | Time is now: 18th May 2024 - 12:42 PM |
