This looks interesting (High output WSOP alternator) |
pete000 |
Jul 18 2018, 02:46 PM
Might be a good solution for my dim head lights !
Not cheap though, ouch ! Attached thumbnail(s) |
Mikey914 |
Jul 18 2018, 03:08 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I do like having options, however now that you have a bigger "pump" will you be able to utilize the additional capacity with the existing blumbing (water analogy).
As thats peak output, and its doubtful that youll need it all, im curious as to how this pans out. There was another member that was doing this some time ago, and if I recall correctly they worked well. Cooling is also an issue gor these. Threr is a finite limit to cooling capacity, as long as its not exceeded would be fine. |
Jul 18 2018, 03:34 PM
914-6 GT in waiting Group: Members Posts: 19,274 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Switch to led's for headlights, tail lights and throughout the car. Not only will you have good lighting, the led's drawl less current so your wires are less taxed.
sithot |
Jul 18 2018, 04:26 PM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
Switch to led's for headlights, tail lights and throughout the car. Not only will you have good lighting, the led's drawl less current so your wires are less taxed. carmagic.us http://carmagic.us/led7.html Englebert is a 914 guy! |
Jul 18 2018, 04:31 PM
Switch to led's for headlights, tail lights and throughout the car. Not only will you have good lighting, the led's drawl less current so your wires are less taxed. carmagic.us http://carmagic.us/led7.html Englebert is a 914 guy! 914 rubber also. Both good guys |
Lo-Fi Version | Time is now: 19th May 2024 - 06:08 AM |
