> Firewall sound pad options-i see several ideas, What do you have/what would you do?
DRPHIL914
post Jul 23 2018, 10:57 AM
Dr. Phil
I have seen some options out there,
1. Stock
2. After market
a. AA pad
b. Rix914parts- modern material, light weight
c. dynamat
d. 914rubber pad.
3. -others??
Also in the cab, the rubber sound deadener( I assume this was only for sound or vibration, since it is rubber I doubt it did much for heat) - I pull this out it was stock and am trying to decide if I should put it back in again or do dynamat or something like this on the inside firewall before putting the backpad back in
Philip W.   Firewall sound pad options-i see several ideas   Jul 23 2018, 10:57 AM
914Sixer   Inside the cab rubber mat was just for noise that ...   Jul 23 2018, 11:35 AM
Philip W.   Inside the cab rubber mat was just for noise that...   Jul 23 2018, 11:59 AM
dr914@autoatlanta.com   ours is dye cut is waterproof and made from dyna m...   Jul 23 2018, 11:42 AM
Philip W.   ours is dye cut is waterproof and made from dyna ...   Jul 25 2018, 09:02 AM
Mueller   Anyone try Lizard Skin? https://www.summitracing...   Jul 23 2018, 12:10 PM
partwerks   Anyone try Lizard Skin? [url=https://www.summit...   Dec 21 2019, 09:08 PM
Mikey914   Stock will hold water and is pretty heavy, however...   Jul 23 2018, 05:46 PM
Olympic 914   Used the X mat from Eastwood. Kind of like dynamat...   Jul 23 2018, 06:43 PM
forrestkhaag   I like what I see but I am taking a different appr...   Jul 23 2018, 07:33 PM
bbrock   I'm leaning toward reusing my stock mat but sp...   Jul 23 2018, 07:58 PM
Chris914n6   For the engine bay you will want something made to...   Jul 23 2018, 10:13 PM
mgp4591   I've heard people having good results with Nor...   Jul 23 2018, 10:35 PM
Mikey914   Dynamat is perfect for the cockpit side of the fir...   Jul 23 2018, 11:09 PM
saigon71   I put a lot of miles on my teener, so I wanted the...   Jul 24 2018, 06:51 AM
Racer   Personally, I have only removed padding.. never ad...   Jul 24 2018, 07:38 AM
Philip W.   Anyone ever use the dynamat door kits? seems like ...   Jul 25 2018, 08:36 AM
Mikey914   Matt has the dynamat door liners and also did the ...   Jul 25 2018, 09:47 AM
Philip W.   Matt has the dynamat door liners and also did the...   Jul 25 2018, 09:58 AM
Mikey914   Easy to cut you a part, the only hesitation I woul...   Jul 25 2018, 11:25 AM
Philip W.   Easy to cut you a part, the only hesitation I wou...   Jul 25 2018, 12:55 PM
Krieger   I used an extra, stock interior sound pad. I then...   Dec 21 2019, 11:44 PM
Garland   Dr. Phil, Check out my build link Michigan Build I...   Dec 22 2019, 12:44 AM
DRPHIL914   Dr. Phil, Check out my build link [url=http://www...   Dec 22 2019, 12:33 PM
- Lo-Fi Version Time is now: 18th July 2025 - 09:47 PM
