Trouble shooting injectors |
LanceW3544 |
Jul 29 2018, 02:38 PM
Newbie Group: Members Posts: 13 Joined: 25-July 18 From: Grand Rapids Mi Member No.: 22,337 Region Association: None |
First of all forgive my lack of knowledge. I am not new to cars but I am new to 914s. I recently purchased a 1970 914 1.7L. with D. Jet. The previous owner noted that it ran last year but was not able to get running this year. The car is far from perfect but I hope to be a solid start for a EJ20 swap in the next year or so. I would love to get the 1.7 fired up to start taking care of of other issues I am not currently aware of.
So let me start discribing what I am seeing Good Battery- Cranks over good and for a long time if needed Fuel Pump- working well but does not shut off after 1-2 seconds. New plugs New wires New cap and rotor I check the fuel rail and I know I have fuel to the injectors. I am able to fire the car up with starter fluid but ofcourse dies when it is burned off. I have had it runnig several times but is not consistant. I have check the grounds to the batter as well as the injector grounds. I don't know where to go next. Any advice would be appreciated. As you explain your suggestion please don't use abbrevations as I am not framilar with them all yet. Thanks -lance |
Jul 29 2018, 03:25 PM
914-6 GT in waiting Group: Members Posts: 19,259 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I send all our injectors to mr injector. Even if they work, he flow tests before and after cleaning and replaces the seals and hose. $17 each + 6 shipping. Then at least you know you are getting an even amount of fuel to each cylinder. If he can’t get an injector to flow correctly, there’s no charge. I sent him at least 150 injectors in the past couple years.
Tbrown4x4 |
Jul 29 2018, 04:10 PM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
What is your fuel pressure? Stock pump?
Check the lower set of points in the distributor. They provide a signal to the ECU (computer) to fire the injectors. |
Porschef |
Jul 29 2018, 04:38 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Really? Grand Rapids?
Hmmmm, (IMG:style_emoticons/default/idea.gif) there might be a guy, uh, nearby, that knows a bit about 914's... You might wanna start there... Good luck. |
Bartlett 914 |
Jul 29 2018, 05:31 PM
Advanced Member Group: Members Posts: 2,215 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
plugged injectors or bad gas.
worn |
Jul 29 2018, 05:35 PM
can't remember Group: Members Posts: 3,153 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
LanceW3544 |
Jul 29 2018, 07:21 PM
Thank you everyone for your quick response. I am very grateful for the help (IMG:style_emoticons/default/smile.gif) mepstein- Great suggestion and for the price hard to beat. I want to try one or two more things before I send them out. Tbrown4x4- Just replaced fuel pump with stock replacement. Not sure what fuel pressure is as I don't have a gauge hooked up inline. In regards to the points. They looked OK but to be honest I don't know what a bad set up points would look like. Can you give me any insight in that direction. Is there a way to test and see if the trigger points are sending a signal? Porschef- Sounds like you know somone in Grand Rapids and if so... I would love a local contact Bartlett 914- There was only a gallon or so of gas in the tank when I got it. I put in dry gas and also 4 gallons of 93 octane. Hopefully that would have done the trick for the gas situation and regard to the injectors I think we all can agree they might be clogged. I wish ther was a way to test and see if the injectors are even trying to open. I pull the fuel rail last night and turned the car over an nothing came out. Not a drop. worn- Great luandry list of items. How do I test and see if the fuel pressure regulator or cyclinder head sensor is not working? |
Freezin 914 |
Jul 29 2018, 08:07 PM
Senior Member Group: Members Posts: 852 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
Really? Grand Rapids? Hmmmm, (IMG:style_emoticons/default/idea.gif) there might be a guy, uh, nearby, that knows a bit about 914's... You might wanna start there... Good luck. He is referring to McMark, he is the owner of original customs, very knowledgeable and a great guy. He has advertisements and is a Administrator on this site. He is your guy. Good luck! And...... (IMG:style_emoticons/default/welcome.png) |
Mark Henry |
Jul 29 2018, 09:07 PM
Down and dirty way to check on injectors is to remove them and with a pin press the pintle. Good they have a bit of give and you may even feel a slight click, seized they will be hard as a rock.
914 RZ-1 |
Jul 29 2018, 09:52 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I hooked a 9v battery up to the injectors to see if they made a clicking noise. You need 3 hands to do it, though! Put the injector (gently) in a vise and use your two hands to attach the wires.
I made a pressure gauge out of some tubing (fuel line at FLAPS*), small hose clamps and a pressure gauge to test fuel pressure (I think it was about $15 for the whole thing). I think it's supposed to be 29 psi on a 1.7. I also recommend Mr. Injector. He's inexpensive and quick. When my trigger points (not to be confused with the "points"-the "trigger points" are housed below the distributor cap) went bad, the car bucked like a bronco. It would turn over, but not start. I think you can check for continuity with a multi-meter. I'm not sure if these can be fixed or if you have to buy new or working used ones. Mine didn't look bad; they just didn't work. (*Friendly Local Auto Parts Store) |
Jul 29 2018, 10:11 PM
914 Idiot Group: Members Posts: 14,983 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Your engine needs three things to run: Fuel, air, and spark.
An extra spark plug with the threaded part taped to a ground hooked up to one of your plug wires should show visible sparks when you crank the starter. You can remove the injectors from one side of the motor (one M6 nut/10mm head each) and put the injectors into a jar. They should spray when you crank the starter. Or you can see if the tailpipe smells of fuel after cranking the starter for a while. A compression test will tell you if you are getting air. I would suggest making sure that all wires and hoses are plugged in securely to the right places. That's a very worthwhile first step... --DD |
Chris914n6 |
Jul 30 2018, 04:02 AM
Jackstands are my life. Group: Members Posts: 3,316 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Unplug the coil - don't want any sparks for the next part. Unbolt the injectors from the manifold but keep them plumbed, you want to see if they are leaking or spraying. If you have no action check the trigger points. If still no action report back I'll write out the next steps.
You probably have someone local that does the injector cleaning and flowing, they all use the same piece of equipment. I've got 6 in Vegas.... |
Bartlett 914 |
Jul 30 2018, 05:05 AM
So it runs with starter fluid. That speaks a lot. If you only had a gallon of gas and you add more without draining the old you may have left bad crap in the line. Water is a real problem! I have had several problems with water in the gas. Pull the injectors as suggested and point them in a jar to see it fuel is coming out. Go from there. Lots of luck.
Come to Garolds this weekend with or without the 914 |
jonferns |
Jul 30 2018, 05:54 AM
Cruzin Performance is in Traverse City, MI. Just sent a set of injectors to him for flow test & cleaning; mailed on a Tuesday, back in hand by Monday. Great service
LanceW3544 |
Jul 30 2018, 03:51 PM
Jonferns- How much do they charge for the injector cleaning.
I just jar tested the injectors. they did not spray at all. May cyclinder 4 just a tad. when I press on the pintle it sprays well. |
Jul 30 2018, 03:57 PM
Still could be an unplugged MPS, or a set of unplugged trigger points. Don't automatically blame the injectors themselves--though they could indeed be the problem.
Check the whole engine bay for wires that are unplugged, or for ones that are not securely plugged in. Make sure the multiple ground point at the rear crankcase seam has six wires going to it, in three pairs. --DD |
brant |
Jul 30 2018, 04:08 PM
Jonferns- How much do they charge for the injector cleaning. I just jar tested the injectors. they did not spray at all. May cyclinder 4 just a tad. when I press on the pintle it sprays well. The fuel injection points in the bottom of the distributor fires a pair of injectors at a time did any of the 4 spray during the jar test, or none? |
LanceW3544 |
Jul 30 2018, 04:15 PM
I created all new grounds for the white injectors wires on the passenger side of the crank case. 6 white wires and one brown. To ensure they were grounded I also ran a ground from the battery to this area to make sure. still no spray. (IMG:style_emoticons/default/sad.gif)
I only checked the driver sided as they are more accessable. I will check all 4 now. what is the MPS sensor? I will check to ensure that is plugged in? |
jonferns |
Jul 30 2018, 04:57 PM
Jonferns- How much do they charge for the injector cleaning. I just jar tested the injectors. they did not spray at all. May cyclinder 4 just a tad. when I press on the pintle it sprays well. They charge $20/injector. They include painting the bodies and new injector seals. |
LanceW3544 |
Jul 30 2018, 05:27 PM
pull all 4 injectors and none of them are spraying. If I press on the tip and they spray no problem. Where to look next?
Lo-Fi Version | Time is now: 10th May 2024 - 02:14 PM |
