2.0L D-Jet Failed ECU? |
MDTerp |
Jul 29 2018, 08:11 PM
Member Group: Members Posts: 101 Joined: 20-May 08 From: Maryland Member No.: 9,075 Region Association: MidAtlantic Region |
I think my ECU failed but I've heard "they never fail". Went to start the car today and didn't hear the normal 1.5 sec fuel pump run and injectors click. Tried starting anyway and cranks but didn't fire as expected.
Checked power at fuel pump with a helper turning the key and no power. Went through Jeff Bowlsby's fuel pump troubleshooting list and relays, relay board, wire harness all checked out. So I pulled the ECU 028000052 and replaced it with a spare ECU 0280000037. Turned key to start position and fuel pump ran and injectors clicked. Started the car but the idle was rough and eventually died. I think the 0280000037 isn't compatible. Car is a 75, Engine 74 case/exhaust 2.0L MPS - 0280100043 CHT Sensor - 0280130012 Distributor - 0231174001 Engine ran great before this problem with no issues. It has 2k miles since rebuild and being sorted out at a reputable shop. Any advice welcomed. thanks, Michael |
Tom_T |
Jul 29 2018, 08:24 PM
Sorry Michael, but they can & do fail.
FIC rebuilds them, & their predecessor company name BRET did so since the 1970s. http://fuelinjectioncorp.com/ I've had a BRET rebuilt one in mine 73 2L since the early 1980's. Porsche also used to rebuild them & resell, & you can occasionally find an NOS one FS around on here, 914club, TheSambe, evil-bay, etc. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
JeffBowlsby |
Jul 29 2018, 10:54 PM
914 Wiring Harnesses Group: Members Posts: 8,501 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The 037 ECU is not a match for your 75 2.0L. It would need the 037 (73 2.0L) MPS to be a match.
I would be willing to test the function of your ECU if you want to send it to me, I have the full diagnostic equipment. I cannot repair it but can verify which functions work/don't work. If it works I would ship it back to you for the cost of shipping. If it does not work...you donate it to me for further research.. Attached image(s) |
MDTerp |
Jul 30 2018, 07:33 AM
The 037 ECU is not a match for your 75 2.0L. It would need the 037 (73 2.0L) MPS to be a match. I would be willing to test the function of your ECU if you want to send it to me, I have the full diagnostic equipment. I cannot repair it but can verify which functions work/don't work. If it works I would ship it back to you for the cost of shipping. If it does not work...you donate it to me for further research.. I can ship you my ECU for research as I'm pretty sure it's not functioning correctly. You wouldn't happen to have a 028000052 ECU to sell me? |
JeffBowlsby |
Jul 30 2018, 08:39 AM
Thanks, I will PM you my address. Sorry, I don’t have an 052 ECU to offer you.
Lo-Fi Version | Time is now: 12th May 2024 - 06:14 PM |
