Dip Stick seal |
Dip Stick seal |
malcolm2 |
Aug 7 2018, 07:57 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
L-jet FI system so I am always monitoring vacuum leaks. I checked my oil the other day and notice a Ho-Made seal at the top of the dip stick. You know down (or UP) inside the little "hat" just below the finger loop. Looks like the PO added a few o-rings. And they are now stretched, twisted and sliding off.
I suppose the reading on the stick could have been off by a smidge all these years too... (IMG:style_emoticons/default/blink.gif) Is there a better repair? |
malcolm2 |
Aug 7 2018, 08:13 AM
I found a post on Itinerant about leaking or blowing oil thru the dip stick tube. This shows a 6mm oring and then a 5mm oring. They say it sealed the tube great. kinda confirms my oil measurement theory.
jim_hoyland |
Aug 7 2018, 08:27 AM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I use the Bus dip stick seal fo the temp-gauge dipstick (NLA), VW shops carry them
Attached thumbnail(s) |
Mikey914 |
Aug 7 2018, 03:29 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I can look at making a correct one, I did notice that I had oil oil leaking out at high RPM (wind-age seal issue?). Just checked my seal used for the taco plate, it works ok.
https://shop.914rubber.com/Oil-Temp-Wiring-...m?categoryId=-1 Attached thumbnail(s) |
malcolm2 |
Aug 7 2018, 04:18 PM
I did plan to checkout your site. Maybe just need to add some marks on the stick (IMG:style_emoticons/default/wink.gif)
malcolm2 |
Aug 8 2018, 07:21 PM
So no one has had to replace the dip stick seal?
Lo-Fi Version | Time is now: 2nd June 2024 - 07:30 PM |
