| DNHunt |
Jun 14 2005, 09:55 AM
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
What happens when the CHT fails with Megasquirt. The warm up enrichment defaults to the value assigned to -40 degrees. In my case it was 240% enrichment.
One moment the engine is running fine the next it quits. There was a big cloud of black smoke. I take it out of gear and coast to the side of the road. I tried to restart it but it was frozen. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) So, I get out to look for the big puddle of oil. Nothing, I look at the top of the engine and it's fine but I smell gas. Luckily I was close to home so I hump it and come back later with the computer. The coolant temp reads -40 so I knew it was flooded. I reset the -40 bin to 130 and it reluctantly fired. By the time I got home it was fine. Tommorrow I'll change the oil and put in a spare CHT. Dave |
| Joe Bob |
Jun 14 2005, 10:03 AM
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Too bad ya can't make a rheostat that you can dial in the outside temp for start up or cockpit adjustment when you read anothe cockpit sensor....hmmmm, another flash back/brain fart....never mind....
| dmenche914 |
Jun 14 2005, 12:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
You mean an electronic version of a manual choke??? Cool!!!
I miss the old chokes, My 58 VW had one, the most recent car I can think of with a manual choke was my parents Honda Civic CVCC I think it was about a 1978 year model, I believe they went to auto chokes after that. it was a strange car, last car in California that did not have a catalyst, hence did not require unleaded. It had a third intake valve, and a little pre-combustion chamber in each head. It burned much cleaner with this head design (the CVCC is Controled Vortex Combustion Chamber), and hence met smog requirements without the need for a catalyst. All the other new cars in California already had to have Catalysts, which started on 914's in 1975. |
Lo-Fi Version | Time is now: 11th March 2026 - 02:37 AM |
