Door insulation options, What have you done? is it worth the effort? |
DRPHIL914 |
Aug 8 2018, 09:28 AM
Since my next project is to rebuild the doors, with the 914rubber kits(late doors, '75), before I put the new stuff in I was wondering what you have all done tried in this regard, such as inner door insulation and/or under the door panel .
I was looking at the dynamat door insulation kits, and thought about doing this. Pictures are always nice as well. Phil |
DRPHIL914 |
Aug 8 2018, 01:53 PM
no one? ok well I asked the question in another thread and had a response back from Mark Whitesell that he or his brother put the dynamat kit in one of their cars .
I may order this kit and see how it goes, |
Aug 8 2018, 01:59 PM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You don’t need much. Mostly on the single thickness door panel.
raynekat |
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
dr914@autoatlanta.com |
Aug 8 2018, 02:14 PM
914 Guru Group: Members Posts: 7,841 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
no reason just the plastic vapor barrier, which is critical, then the new window felts inner and outer fuzzies, squeezes, vent window seal and rear window cap
Since my next project is to rebuild the doors, with the 914rubber kits(late doors, '75), before I put the new stuff in I was wondering what you have all done tried in this regard, such as inner door insulation and/or under the door panel . I was looking at the dynamat door insulation kits, and thought about doing this. Pictures are always nice as well. Phil |
Aug 8 2018, 02:15 PM
raynekat |
Aug 8 2018, 05:06 PM
you are blessed because you do not have the bid steel side guards in the doors to have to go around I put your standard Dynomat in the doors and it made an appreciable difference when you closed the doors. Yep....there are advantages to a 71 now and then. (IMG:style_emoticons/default/wink.gif) |
wes |
Aug 8 2018, 05:15 PM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
Lo-Fi Version | Time is now: 9th May 2024 - 02:42 PM |
