Positive battery terminal block, Anyone have pics? |
bbrock |
Aug 8 2018, 05:44 PM
Does anyone have pics of the 914rubber (or original) positive battery terminal block installed? The reason I ask is because I'm ordering new crimp on ring terminals for main and alternator harnesses. I assume that positive terminals from main harness and alternator harness all attach to the M6 bolt on the block. I've misplaced the original terminals I cut off my main harness but the ground terminals all have M6 holes, but the battery end of my alternator harness is 8mm diameter. It's very possible that someone (probably me) drilled that terminal out to fit on a 1/2" terminal bolt but I can't tell. So I guess my real questions are what are the right sizes for terminals and where on the battery terminal do they attach? The only photo I can find in the factory manual doesn't show enough detail. (IMG:style_emoticons/default/confused24.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/shop.914rubber.com-20845-1533771867.1.jpg) |
Dave_Darling |
Aug 8 2018, 05:51 PM
I don't believe the original ones had a block. I think they had individual wires coming out.
Though I'm not sure I've ever actually looked at an original positive wire... --DD |
ejm |
Aug 8 2018, 07:15 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,692 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
I assume that positive terminals from main harness and alternator harness all attach to the M6 bolt on the block. I've misplaced the original terminals I cut off my main harness but the ground terminals all have M6 holes, but the battery end of my alternator harness is 8mm diameter. The 8mm ring on the alternator harness goes on the battery cable post on the starter. The harness eyes on the battery terminal are 6mm. |
bbrock |
Aug 8 2018, 07:50 PM
I assume that positive terminals from main harness and alternator harness all attach to the M6 bolt on the block. I've misplaced the original terminals I cut off my main harness but the ground terminals all have M6 holes, but the battery end of my alternator harness is 8mm diameter. The 8mm ring on the alternator harness goes on the battery cable post on the starter. The harness eyes on the battery terminal are 6mm. Aha! That makes sense! Many thanks. (IMG:style_emoticons/default/smilie_pokal.gif) |
IronHillRestorations |
Aug 8 2018, 09:27 PM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
The original looks like the repro from 914rubber, but the OEM was a single block and stud.
There's a problem with the fasteners intersecting on the repro, the M6 and M8 hit and you can't get enough threads in one or the other. I got a few to have on hand. My plan was to cut off part of M8 stud and braze it to the block. After getting these in hand, I probably would've put SAE thread on the clamp stud, just so you can use a SAE battery clamp nut. |
JeffBowlsby |
Aug 9 2018, 07:56 AM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Attached thumbnail(s) |
ClayPerrine |
Aug 9 2018, 09:17 AM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
That looks like the one on Elwood (factory six). I had never seen one until we got him. The screw on top is M6. The one for the bolt is M8. you could take a 10MM square cube, drill and tap one side for M8, and on a side 90 degrees from the M8 hole and drill and tap for M6. Then use a bolt instead of a nut through the battery cable end. Put a M6 screw in the top and attach the wires. Beats trying to put all the wires under the battery cable bolt. |
Lo-Fi Version | Time is now: 20th May 2024 - 11:13 AM |
