914-4 2L #3 rod bearing failure |
Driver174 |
Aug 8 2018, 11:50 PM
Member Group: Members Posts: 106 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None |
ClayPerrine |
Aug 9 2018, 06:43 AM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I have seen it in a street engine. That is the rod bearing that is farthest from the oil feed to the crank. So it is the first to suffer with oil starvation. It could be anything from an incorrectly installed main bearing restricting the oil flow to the crank, or some debris in the oil feed passage.
Hard to tell what caused it, but I would replace the crank and rods as a precaution. |
stownsen914 |
Aug 9 2018, 06:59 AM
Looks like an aftermarket rod in the pic at top? What rods are you using? Bearings? Any special prep on crank? Any details you can share on usage may help too - hp, RPM, any other significant details. Lots of variables for a race motor that can impact longevity, like oil temp, anything to help with oil starvation in corners (especially of you are running sticky tires).
Lo-Fi Version | Time is now: 17th May 2024 - 08:25 PM |
