914-4 2L #3 rod bearing failure |
Driver174 |
Aug 8 2018, 11:50 PM
Member Group: Members Posts: 106 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None |
yeahmag |
Aug 14 2018, 10:40 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Had this happen to my rod bearings twice even while running Brad Penn, a tuna can, and 1/2 quart over. What I found was happening (based on logging oil pressure) was the oil was not draining back fast enough. If you don't want to go dry sump (which I did) you can try blocking off the head vents and enlarging the case vent. The idea is to keep the heads at a higher pressure than the case to increase oil flow (return) back to the case. I run a -10AN line from the chimney to a cheap breather.
Lo-Fi Version | Time is now: 17th May 2024 - 08:26 PM |
