Headlight Switch Wiring/Fog Lamp Issue |
tvdinnerbythepool |
Aug 10 2018, 11:52 AM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Hi all,
Looking for some help with my headlight switch and fog lights. I swapped my headlight switch out with the correct part #. It had a bad switch from a VW. I drew up the wiring from the manual shown below. My car didn't match it 100%, mostly pole #15. I didn't have a red/white or a red left over. I did however have a jumper wire attached from the battery #30 pole, I plugged that into #15 and got the headlights working. Does that jive with you guys? The issue I'm having is with the fog lamps. Headlight switch in and off - No Fog Lights = Correct Headlight Switch 1 notch out - Running lights ON and Fog Lights turn on when asked to = correct Headlights all the way out - So...I pull it all the way out and jiggle the switch a little and the headlights pop out and turn On, Good. However, when they do, the fog lights shut OFF even when selected on... This is where i'm a little lost...is something grounding out? Is it yet another bad switch? If I jiggle the switch and the headlights shut off, the fog lights turn back on. Both won't stay on at the same time. I replaced both relays as they were bad and I believe these to not be the issue. Any help would be appreciated! Attached thumbnail(s) |
JeffBowlsby |
Aug 10 2018, 11:57 AM
914 Wiring Harnesses Group: Members Posts: 8,522 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
That is the correct function. Think about it...in dense fog, you want fog lights on to light the road under the fog, and not the headlights on which just light up the fog.
oakdalecurtis |
Aug 10 2018, 12:17 PM
Oakdalecurtis Group: Members Posts: 1,327 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Ok TV, here's the deal. The stock setup is that the fog lights should be able to go on AS LONG AS THE HEADLIGHTS ARE ON LOW BEAM. If that is the case, then when you switch your headlights to high beam, the fog lights will go off. That is because high beams in fog is a no no, too blinding to the driver. That said, I would suggest doing what I did. Using a new relay, rewire the hot lead to the fog lights directly to the fog light switch, independent of the headlight switch. Why do this you ask? Because then you can operate your fog lights on dreary days as Daylight Running Lights to increase your visibility, without your headlights having to be up. I like this setup much better than the stock rigamarole. (IMG:style_emoticons/default/cheer.gif)
tvdinnerbythepool |
Aug 10 2018, 02:18 PM
Ok TV, here's the deal. The stock setup is that the fog lights should be able to go on AS LONG AS THE HEADLIGHTS ARE ON LOW BEAM. If that is the case, then when you switch your headlights to high beam, the fog lights will go off. That is because high beams in fog is a no no, too blinding to the driver. That said, I would suggest doing what I did. Using a new relay, rewire the hot lead to the fog lights directly to the fog light switch, independent of the headlight switch. Why do this you ask? Because then you can operate your fog lights on dreary days as Daylight Running Lights to increase your visibility, without your headlights having to be up. I like this setup much better than the stock rigamarole. (IMG:style_emoticons/default/cheer.gif) Maybe I'm on high beam then? I just got the car so I'm still figuring it out. Next dumb question....Where's the high-beam switch?! Thanks again! |
oakdalecurtis |
Aug 10 2018, 05:23 PM
Ok TV, here's the deal. The stock setup is that the fog lights should be able to go on AS LONG AS THE HEADLIGHTS ARE ON LOW BEAM. If that is the case, then when you switch your headlights to high beam, the fog lights will go off. That is because high beams in fog is a no no, too blinding to the driver. That said, I would suggest doing what I did. Using a new relay, rewire the hot lead to the fog lights directly to the fog light switch, independent of the headlight switch. Why do this you ask? Because then you can operate your fog lights on dreary days as Daylight Running Lights to increase your visibility, without your headlights having to be up. I like this setup much better than the stock rigamarole. (IMG:style_emoticons/default/cheer.gif) Maybe I'm on high beam then? I just got the car so I'm still figuring it out. Next dumb question....Where's the high-beam switch?! Thanks again! Left stalk, pull |
tmc914 |
Aug 10 2018, 06:16 PM
Member Group: Members Posts: 116 Joined: 24-September 17 From: Lowell, MA Member No.: 21,452 Region Association: North East States |
Sometimes the little blue light on the display is hard to see. Had my high beams on when I first got my car and didn't know until someone here mentioned how dim the indicator light can be. Just pull back on the turn signal stalk and it will click over via relay. Pull back again to switch back.
Rob-O |
Aug 10 2018, 10:20 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Sometimes the little blue light on the display is hard to see. Had my high beams on when I first got my car and didn't know until someone here mentioned how dim the indicator light can be. Just pull back on the turn signal stalk and it will click over via relay. Pull back again to switch back. That's true. It's not the bulb that's dim, though. It's that the little blue piece of plastic has degraded to such an extent that very little light can get past it. Go to Staples and buy some hanging folder tabs...the see-through kind. They come in colors. Guess which colors...red (fuel low level warning lamp), yellow (turn signal indicator), blue (high beam indicator) and green (running light indicator). |
Lo-Fi Version | Time is now: 29th May 2024 - 02:47 PM |
