Hi all,
Looking for some help with my headlight switch and fog lights. I swapped my headlight switch out with the correct part #. It had a bad switch from a VW.
I drew up the wiring from the manual shown below.
My car didn't match it 100%, mostly pole #15. I didn't have a red/white or a red left over. I did however have a jumper wire attached from the battery #30 pole, I plugged that into #15 and got the headlights working. Does that jive with you guys?
The issue I'm having is with the fog lamps.
Headlight switch in and off - No Fog Lights = Correct
Headlight Switch 1 notch out - Running lights ON and Fog Lights turn on when asked to = correct
Headlights all the way out - So...I pull it all the way out and jiggle the switch a little and the headlights pop out and turn On, Good. However, when they do, the fog lights shut OFF even when selected on... This is where i'm a little lost...is something grounding out? Is it yet another bad switch? If I jiggle the switch and the headlights shut off, the fog lights turn back on. Both won't stay on at the same time.
I replaced both relays as they were bad and I believe these to not be the issue.
Any help would be appreciated!
