Fuel Filter - which one?, For '74 1.8 w/ fuel pump relocated to front. |
auto_cran |
Aug 12 2018, 05:27 PM
Member Group: Members Posts: 56 Joined: 12-February 12 From: Dallas, Texas Member No.: 14,123 Region Association: None |
Previous owner relocated the fuel pump and filter to the front. Looks like a nice, clean job. I recently had some drive-ability issues and since the time I've owned the car (a few years now) I've never replaced the filter, so figure I'd start there and change it out - simple enough (so I thought).
Old filter was a very small plastic in-line filter which accommodated the different hose sizes. Bought a NAPA Gold/Wix 3274 (square/box type), installed it, checked for leaks - all good, no problem. Figured I was all done, I went to reinstall the access panel to discover I can't get it back on without the new filter touching the steering rack, which I don't want it to do. There doesn't seem to be much room in there. This is probably why the PO used the small one he had. I went to a few auto parts stores to find one that matched the one the PO had - and found one - except the flow (indicated by arrows) was in the opposite direction, so that was a no go. For those of you that relocated the fuel pump to the front - what filter are you using? Any help or advice would be greatly appreciated! Chris |
dr914@autoatlanta.com |
Aug 14 2018, 09:09 AM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we are using the round Mahle filter for fuel pump relocations, works perfectly, is a factory substitute for the original square one
Previous owner relocated the fuel pump and filter to the front. Looks like a nice, clean job. I recently had some drive-ability issues and since the time I've owned the car (a few years now) I've never replaced the filter, so figure I'd start there and change it out - simple enough (so I thought). Old filter was a very small plastic in-line filter which accommodated the different hose sizes. Bought a NAPA Gold/Wix 3274 (square/box type), installed it, checked for leaks - all good, no problem. Figured I was all done, I went to reinstall the access panel to discover I can't get it back on without the new filter touching the steering rack, which I don't want it to do. There doesn't seem to be much room in there. This is probably why the PO used the small one he had. I went to a few auto parts stores to find one that matched the one the PO had - and found one - except the flow (indicated by arrows) was in the opposite direction, so that was a no go. For those of you that relocated the fuel pump to the front - what filter are you using? Any help or advice would be greatly appreciated! Chris |
Lo-Fi Version | Time is now: 18th May 2024 - 05:07 PM |
