SOT - Painting Bare Metal, Best Procedure |
saigon71 |
Aug 15 2018, 08:04 AM
Senior Member Group: Members Posts: 1,999 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I'm in the process of stripping a set of vending machines down to bare metal to repaint. It will be a rattle can paint job. I'm behind schedule on this install and it's a high-end account, so I want to nail this. I've already screwed up once painting these.
I consider myself a pretty decent DIY'er, but painting of any type has always been a trouble spot for me. I used 80 grit sandpaper to remove the old paint. Is it necessary to sand the bare metal with a finer grit before priming? If so, what grit should I go down to? Any other tips on the overall process would be appreciated. |
Andyrew |
Aug 15 2018, 08:38 AM
Your using a rattle can? I would find some high build primer and read the can.
Your going to get a finer mist out of a can than with a guy with a 1.8 or 2.2 tip. That finer mist will not cover scratches well. If it were me I would get some 220grit D/A paper and sand it down with that. Your really not going to see 220 grit scratches and a DA does a good job of making scratches that wont transfer well to the final surface. |
Lo-Fi Version | Time is now: 18th May 2024 - 09:40 AM |
