Wanted: L-Jet system, considering for my Bus project |
malcolm2 |
Aug 15 2018, 12:31 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Just feeling out the group. Wondered if there was anyone removing an L-jet. Or if there were spare parts lying around. Kinda like a pay-it-forward thing. I have been on both ends of that deal. That is what most of us do from time to time.
I picked L-Jet cause that is what I have on my 75. I suppose I could learn the D-Jet system too. My bus has a 1.7 TIV. Throw out some offers, let's see what is out there. Thanks |
Alapone |
Aug 15 2018, 01:17 PM
Member Group: Members Posts: 105 Joined: 4-April 13 From: Nj Member No.: 15,734 Region Association: None |
Just feeling out the group. Wondered if there was anyone removing an L-jet. Or if there were spare parts lying around. Kinda like a pay-it-forward thing. I have been on both ends of that deal. That is what most of us do from time to time. I picked L-Jet cause that is what I have on my 75. I suppose I could learn the D-Jet system too. My bus has a 1.7 TIV. Throw out some offers, let's see what is out there. Thanks Doesn’t help you I’m sure but I have a d jet system I’m looking to get rid of. |
malcolm2 |
Aug 15 2018, 02:42 PM
Just feeling out the group. Wondered if there was anyone removing an L-jet. Or if there were spare parts lying around. Kinda like a pay-it-forward thing. I have been on both ends of that deal. That is what most of us do from time to time. I picked L-Jet cause that is what I have on my 75. I suppose I could learn the D-Jet system too. My bus has a 1.7 TIV. Throw out some offers, let's see what is out there. Thanks Doesn’t help you I’m sure but I have a d jet system I’m looking to get rid of. I'll check for some posts and ask around to see. Not sure why, but the L-Jet was used on the 1.8 engines and the D-Jet on 1.7 and 2.0. I think the 73+ buses use L-jet on the 2.0. Again, I will study up and reply back. Maybe someone will chime in here. Thanks, Clark |
jim_hoyland |
Aug 15 2018, 04:49 PM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I have a few parts. A nearby member converted to carbs and left me with the 1.8 L-Jet FI; i’ve Used a few of the components. I can shoot a pic and email you (need an email addy)
Mueller |
Aug 15 2018, 05:02 PM
I've installed the 1.8 L-jet stuff on a 2.0 and it ran great.
jcd914 |
Aug 15 2018, 06:34 PM
I have some L-jet parts, not sure what all is there but depending on what Jim has I may be able to fill in some gaps.
IMHO L-jet works best on something other than a stock 1.8. I have installed L-jet on both 1.7 and 2.0 engines and it worked better than any stock 1.8 I ever drove. Stock 1.8 had really low compression and it made the engine and system really sensitive to vacuum leaks, particularly at idle. Too lean at idle and you get intake backfires that ruin your AFM. IMHO, L-jet is a newer and better FI system that D-jet. Jim |
malcolm2 |
Aug 15 2018, 07:52 PM
I have some L-jet parts, not sure what all is there but depending on what Jim has I may be able to fill in some gaps. IMHO L-jet works best on something other than a stock 1.8. I have installed L-jet on both 1.7 and 2.0 engines and it worked better than any stock 1.8 I ever drove. Stock 1.8 had really low compression and it made the engine and system really sensitive to vacuum leaks, particularly at idle. Too lean at idle and you get intake backfires that ruin your AFM. IMHO, L-jet is a newer and better FI system that D-jet. Jim interesting. I made my 914 1.8 engine into a 1911 with a cam from type4store and a recommended CR of below 8. I do experience idle issues and sensitivity to vac leaks. So how low a CR are you talking? |
djway |
Aug 15 2018, 10:00 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
Looking for L Jet parts myself
Anyone know the differences between a bay window and 914 control box programming? |
jim_hoyland |
Aug 16 2018, 12:43 PM
Here are pics of what is available I may have a few additional small parts, but this is what I could see.
AFM not included, but they available used or reman Asking $500 + shipping Attached image(s) |
malcolm2 |
Aug 16 2018, 07:50 PM
Looking for L Jet parts myself Anyone know the differences between a bay window and 914 control box programming? Good question. But i would ask why would there be a difference. I am sure there is tho. (IMG:style_emoticons/default/popcorn[1].gif) |
djway |
Aug 17 2018, 02:06 AM
I would think that the motors are going to be expected to do different things ie heavy push and light higher rev???
That FI system is missing a major component if it is L Jet |
malcolm2 |
Aug 17 2018, 07:17 AM
That FI system is missing a major component if it is L Jet Let's play that game. I see 2 parts missing...... Dual Relay, and the 4 little cigarettes. (IMG:style_emoticons/default/rolleyes.gif) |
djway |
Aug 17 2018, 10:57 AM
AFM
jim_hoyland |
Aug 17 2018, 12:49 PM
That FI system is missing a major component if it is L Jet Let's play that game. I see 2 parts missing...... Dual Relay, and the 4 little cigarettes. (IMG:style_emoticons/default/rolleyes.gif) Thanks for noticing: I have the resistor pack and a dual relay. The AFM needs to be sourced; peeps that converted to Carbs are good sources |
jtprettyman |
Aug 17 2018, 03:31 PM
Rust Bucket Owner Group: Members Posts: 109 Joined: 5-May 15 From: Murfreesboro Tennessee Member No.: 18,707 Region Association: South East States |
Clark -
I'm 95% sure I'll be going with carbs (and a different motor) on mine. No guarantee anything is fully functional (other than the throttle body!), but you are welcome to the FI setup from mine. |
djway |
Aug 17 2018, 07:18 PM
jcd914 |
Aug 18 2018, 12:13 AM
I have some L-jet parts, not sure what all is there but depending on what Jim has I may be able to fill in some gaps. IMHO L-jet works best on something other than a stock 1.8. I have installed L-jet on both 1.7 and 2.0 engines and it worked better than any stock 1.8 I ever drove. Stock 1.8 had really low compression and it made the engine and system really sensitive to vacuum leaks, particularly at idle. Too lean at idle and you get intake backfires that ruin your AFM. IMHO, L-jet is a newer and better FI system that D-jet. Jim interesting. I made my 914 1.8 engine into a 1911 with a cam from type4store and a recommended CR of below 8. I do experience idle issues and sensitivity to vac leaks. So how low a CR are you talking? Stock US 914 1.8 is 7.3:1 compression ratio (new before wearing out). Euro 1.8 is 8.6:1 (carb'd engine) Early 1.7 is 8.2:1 US 2.0 are 7.6:1 Euro 2.0 are 8.0:1 All L-jet engine are sensitive to vacuum leaks, leaks mean lean mixture on L-jet On D-jet vacuum leaks actually cause rich running because the MPS see lower vacuum and assumes more load on the engine. L-jet "measures" the air going into the engine a supplies fuel for the amount of air going in. If it doesn't measure all the air it does not add enough fuel for the air. By today's standards it is a crude system but in 1974 it was a new state of the art system and D-jet was old school. Jim |
jcd914 |
Aug 18 2018, 12:16 AM
That FI system is missing a major component if it is L Jet Let's play that game. I see 2 parts missing...... Dual Relay, and the 4 little cigarettes. (IMG:style_emoticons/default/rolleyes.gif) Thanks for noticing: I have the resistor pack and a dual relay. The AFM needs to be sourced; peeps that converted to Carbs are good sources Jim does the harness have a 6 or 7 pin AFM connector? I'll try to look and see if I have any AFM's that might be any good. Jim |
jim_hoyland |
Aug 18 2018, 05:59 AM
It's a 7 pin connector for the AFM
Lo-Fi Version | Time is now: 17th May 2024 - 05:40 PM |
