Any clues as to engine size? |
Tdskip |
Aug 15 2018, 05:02 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Hi guys-hope everybody's having a good day. I was fortunate off to get a ton of help from Forest and Keith today getting the "turbo" clutch issue sorted out. I can't say enough about how helpful they were and gracious with their time.
One of the things that I suspected, but it appears we now have proof of, is that this engine was built up from the original 2.0 GC case spec. Can anyone identify these heads or help make a guess as to displaceme Attached thumbnail(s) |
Tdskip |
Aug 15 2018, 05:03 PM
mepstein |
Aug 15 2018, 05:08 PM
914-6 GT in waiting Group: Members Posts: 19,253 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Guess displacement with a picture!
Tdskip |
Aug 15 2018, 05:23 PM
Guess displacement with a picture! Yep - that gives you some evidence of how high of esteem I hold all of your knowledge. Actually, while that is true, the idea is that someone may have built a 2 L motor with similar heads and jugs and would be able to recognize the set up . I hope you're having a good week! |
jcd914 |
Aug 15 2018, 05:39 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
You can't tell engine displacement from pictures of the heads.
If you had the right pictures someone could ID the heads but that doesn't really tell you much. Anyone could use any heads (1.7, 1.8 or 2.0) to build any size engine. For 914 heads, 1.7 & 1.8 heads have 4 intake studs and 2.0 heads have 3 intake studs. On 1.7 & 1.8 heads the spark plug holes are angled up more than 2.0 heads. Those are the prominent visual differences between the heads. Pistons and crank are what change the displacement and you can't see them with the engine assembled. If you have a GC case and 3 stud heads you probably have a 2.0 engine at least. It is common to put bigger pistons and cylinders on as part of a rebuild, so who knows what is under the cylinder head. Jim |
Tdskip |
Aug 15 2018, 05:41 PM
You can't tell engine displacement from pictures of the heads. If you had the right pictures someone could ID the heads but that doesn't really tell you much. Anyone could use any heads (1.7, 1.8 or 2.0) to build any size engine. For 914 heads, 1.7 & 1.8 heads have 4 intake studs and 2.0 heads have 3 intake studs. On 1.7 & 1.8 heads the spark plug holes are angled up more than 2.0 heads. Those are the prominent visual differences between the heads. Pistons and crank are what change the displacement and you can't see them with the engine assembled. If you have a GC case and 3 stud heads you probably have a 2.0 engine at least. It is common to put bigger pistons and cylinders on as part of a rebuild, so who knows what is under the cylinder head. Jim And thanks Jim-was hoping that maybe there was something distinctive about the size of the fins and material etc. that would jump out. Appreciate the response |
mepstein |
Aug 15 2018, 05:45 PM
Guess displacement with a picture! Yep - that gives you some evidence of how high of esteem I hold all of your knowledge. Actually, while that is true, the idea is that someone may have built a 2 L motor with similar heads and jugs and would be able to recognize the set up . I hope you're having a good week! heads are only part of the equation. It's hard to know the cylinder size and impossible to know the crank from a pic. Is this the turbo engine? |
Spoke |
Aug 15 2018, 06:16 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I've heard you can measure the stroke with a chopstick in the spark plug hole.
Larmo63 |
Aug 15 2018, 06:25 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Let's ask Carnac............
forrestkhaag |
Aug 15 2018, 06:38 PM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
As you and everyone else can read into this thread is that your question, while well intended and well focused on available investigations today, cannot define what you have in detail.
Having been under there for a few hours today, I would say (as your pictures indicate) that you have a very substantial 4 - built on a 2.0 case - and it doesn't leak at the case, cylinders, or heads or even pesky valve covers. PR tubes are another thing but an easy fix. So all is good for now and it is a safe bet it will serve you for a few thousand miles. But. Is it safe?.......... On your current track, you have ample time to sort out what the engine is. You have a nice backup 4 - 2.0 and working tranny to match / if things go North and crap-out. (I'm from the South) What you know it is,... is.... (the meaning of is is?,.) is you have a strong well built 4 above 2.0 based on the performance you report on first drives / and you have a 912 and another 914-4 so lets just keep on the track of getting the clutch repaired/replaced and get it on the road for a few thousand miles. I think it is safe.... Yes. Its safe. Then we can dabble in what is is .......... (IMG:style_emoticons/default/beerchug.gif) see you at 10 under the lift.a Attached image(s) |
Rand |
Aug 15 2018, 06:40 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
I've heard you can measure the stroke with a chopstick in the spark plug hole. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/av-943.gif) Oh man, only the OGs will appreciate that fully. |
forrestkhaag |
Aug 15 2018, 06:41 PM
If OGeez are Old Jesus freaks, Yes. Thou Shall appreciat thou elders...... Unlike Larmo.
Tdskip |
Aug 15 2018, 11:14 PM
As you and everyone else can read into this thread is that your question, while well intended and well focused on available investigations today, cannot define what you have in detail. Having been under there for a few hours today, I would say (as your pictures indicate) that you have a very substantial 4 - built on a 2.0 case - and it doesn't leak at the case, cylinders, or heads or even pesky valve covers. PR tubes are another thing but an easy fix. So all is good for now and it is a safe bet it will serve you for a few thousand miles. But. Is it safe?.......... On your current track, you have ample time to sort out what the engine is. You have a nice backup 4 - 2.0 and working tranny to match / if things go North and crap-out. (I'm from the South) What you know it is,... is.... (the meaning of is is?,.) is you have a strong well built 4 above 2.0 based on the performance you report on first drives / and you have a 912 and another 914-4 so lets just keep on the track of getting the clutch repaired/replaced and get it on the road for a few thousand miles. I think it is safe.... Yes. Its safe. Then we can dabble in what is is .......... (IMG:style_emoticons/default/beerchug.gif) see you at 10 under the lift.a Thanks! |
Cracker |
Aug 16 2018, 07:31 AM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Going out on a limb here but I suppose it is no less than 1.7 and no more than 2.4... (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/biggrin.gif)
Cracker |
Tdskip |
Aug 16 2018, 09:20 AM
Going out on a limb here but I suppose it is no less than 1.7 and no more than 2.4... (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/biggrin.gif) Cracker Nailed it! |
ValcoOscar |
Aug 16 2018, 09:31 AM
Garage Life Group: Members Posts: 2,378 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
Tom-
From all the replies it appears you have a solid nice engine that surprisingly doesn't leak. Enjoy it as is IMHO (IMG:style_emoticons/default/piratenanner.gif) See ya soon, Oscar |
VaccaRabite |
Aug 16 2018, 09:45 AM
En Garde! Group: Admin Posts: 13,432 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I've heard you can measure the stroke with a chopstick in the spark plug hole. Nah, the angle is wrong. That was finding TDC. And bendy straws work better and don't break off in the bore. (IMG:style_emoticons/default/bootyshake.gif) Zach |
bretth |
Aug 16 2018, 10:39 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Interesting looking cylinders, definitely not cast iron.
ClayPerrine |
Aug 16 2018, 10:58 AM
Life's been good to me so far..... Group: Admin Posts: 15,430 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I've heard you can measure the stroke with a chopstick in the spark plug hole. <twilight zone music plays> I was just thinking about that last night!!! (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/laugh.gif) |
Mueller |
Aug 16 2018, 11:14 AM
Put cylinder 1 at BDC, fill with liquid, measure how much you are putting in minus the combustion chamber volume. (approx 56cc I think?)
(IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 12:20 AM |
