> Any clues as to engine size?
Tdskip
post Aug 15 2018, 05:02 PM
Hi guys-hope everybody's having a good day. I was fortunate off to get a ton of help from Forest and Keith today getting the "turbo" clutch issue sorted out. I can't say enough about how helpful they were and gracious with their time.
One of the things that I suspected, but it appears we now have proof of, is that this engine was built up from the original 2.0 GC case spec.
Can anyone identify these heads or help make a guess as to displaceme
Replies(1 - 19)
Tdskip
post Aug 15 2018, 05:03 PM
post Aug 15 2018, 05:08 PM
914-6 GT in waiting
Guess displacement with a picture!
Tdskip
post Aug 15 2018, 05:23 PM
QUOTE(mepstein @ Aug 15 2018, 06:08 PM) *
Yep - that gives you some evidence of how high of esteem I hold all of your knowledge.
Actually, while that is true, the idea is that someone may have built a 2 L motor with similar heads and jugs and would be able to recognize the set up .
I hope you're having a good week!
jcd914
post Aug 15 2018, 05:39 PM
You can't tell engine displacement from pictures of the heads.
If you had the right pictures someone could ID the heads but that doesn't really tell you much.
Anyone could use any heads (1.7, 1.8 or 2.0) to build any size engine.
For 914 heads, 1.7 & 1.8 heads have 4 intake studs and 2.0 heads have 3 intake studs.
On 1.7 & 1.8 heads the spark plug holes are angled up more than 2.0 heads.
Those are the prominent visual differences between the heads.
Pistons and crank are what change the displacement and you can't see them with the engine assembled.
If you have a GC case and 3 stud heads you probably have a 2.0 engine at least.
It is common to put bigger pistons and cylinders on as part of a rebuild, so who knows what is under the cylinder head.
Jim
Tdskip
post Aug 15 2018, 05:41 PM
QUOTE(jcd914 @ Aug 15 2018, 06:39 PM) *
Jim
And thanks Jim-was hoping that maybe there was something distinctive about the size of the fins and material etc. that would jump out.
Appreciate the response
post Aug 15 2018, 05:45 PM
914-6 GT in waiting
QUOTE(Tdskip @ Aug 15 2018, 07:23 PM) *
heads are only part of the equation. It's hard to know the cylinder size and impossible to know the crank from a pic.
Is this the turbo engine?
Spoke
post Aug 15 2018, 06:16 PM
Jerry
I've heard you can measure the stroke with a chopstick in the spark plug hole.
Larmo63
post Aug 15 2018, 06:25 PM
Let's ask Carnac............
forrestkhaag
post Aug 15 2018, 06:38 PM
As you and everyone else can read into this thread is that your question, while well intended and well focused on available investigations today, cannot define what you have in detail.
Having been under there for a few hours today, I would say (as your pictures indicate) that you have a very substantial 4 - built on a 2.0 case - and it doesn't leak at the case, cylinders, or heads or even pesky valve covers. PR tubes are another thing but an easy fix. So all is good for now and it is a safe bet it will serve you for a few thousand miles.
But. Is it safe?..........
On your current track, you have ample time to sort out what the engine is. You have a nice backup 4 - 2.0 and working tranny to match / if things go North and crap-out. (I'm from the South)
What you know it is,... is.... (the meaning of is is?,.) is you have a strong well built 4 above 2.0 based on the performance you report on first drives / and you have a 912 and another 914-4 so lets just keep on the track of getting the clutch repaired/replaced and get it on the road for a few thousand miles. I think it is safe.... Yes. Its safe.
Then we can dabble in what is is ..........
(IMG:style_emoticons/default/beerchug.gif) see you at 10 under the lift.a
Rand
post Aug 15 2018, 06:40 PM
Cross Member
QUOTE(Spoke @ Aug 15 2018, 04:16 PM) *
(IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/av-943.gif)
Oh man, only the OGs will appreciate that fully.
forrestkhaag
post Aug 15 2018, 06:41 PM
If OGeez are Old Jesus freaks, Yes. Thou Shall appreciat thou elders...... Unlike Larmo.
Tdskip
post Aug 15 2018, 11:14 PM
QUOTE(forrestkhaag @ Aug 15 2018, 07:38 PM) *
Thanks!
Cracker
post Aug 16 2018, 07:31 AM
Going out on a limb here but I suppose it is no less than 1.7 and no more than 2.4... (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/biggrin.gif)
Cracker
Tdskip
post Aug 16 2018, 09:20 AM
QUOTE(Cracker @ Aug 16 2018, 08:31 AM) *
Cracker
Nailed it!
ValcoOscar
post Aug 16 2018, 09:31 AM
Garage Life
Tom-
From all the replies it appears you have a solid nice engine that surprisingly doesn't leak.
Enjoy it as is IMHO (IMG:style_emoticons/default/piratenanner.gif)
See ya soon,
Oscar
VaccaRabite
post Aug 16 2018, 09:45 AM
En Garde!
QUOTE(Spoke @ Aug 15 2018, 08:16 PM) *
Nah, the angle is wrong. That was finding TDC.
And bendy straws work better and don't break off in the bore. (IMG:style_emoticons/default/bootyshake.gif)
Zach
bretth
post Aug 16 2018, 10:39 AM
Interesting looking cylinders, definitely not cast iron.
ClayPerrine
post Aug 16 2018, 10:58 AM
QUOTE(Spoke @ Aug 15 2018, 07:16 PM) *
<twilight zone music plays>
I was just thinking about that last night!!! (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/laugh.gif)
Mueller
post Aug 16 2018, 11:14 AM
914 Freak!
Put cylinder 1 at BDC, fill with liquid, measure how much you are putting in minus the combustion chamber volume. (approx 56cc I think?)
- Lo-Fi Version Time is now: 5th July 2025 - 03:05 PM
