2 Pages V < 1 2
> Any clues as to engine size?
Dave_Darling
post Aug 16 2018, 11:49 AM
Post #21
914 Idiot
The cylinders don't look like cast iron. Chances are they aren't a stock diameter, in that case. Likely between 96mm and 105mm. (Note that each statement in that chain is more and more speculative.)
"Button it up and drive it" sounds like the best advice. (IMG:style_emoticons/default/smile.gif)
--DD
Mark Henry
post Aug 16 2018, 12:09 PM
Post #22
that's what I do!
QUOTE(bretth @ Aug 16 2018, 12:39 PM) *
Interesting looking cylinders, definitely not cast iron.
Those are aircraft cylinders, likely modified Lycoming or Continental.
Even the head casting looks odd, take the tins off and lets see.....
brant
post Aug 16 2018, 01:21 PM
Post #23
There is a test that is used by race organizations to "pump" a motor and discern displacement.
I believe it takes some equipment
I don't know how, nor whom can do it
but google it...
there is a test
you can likely pay a race shop to test it for you and give you some accurate informed guess....
leak down can throw the test results off, so run a leak down test first and then have the motor pumped.
brant
2 Pages V < 1 2
- Lo-Fi Version Time is now: 13th September 2026 - 06:28 AM
