Gas smell inside? |
Gas smell inside? |
dgraves |
Aug 15 2018, 05:57 PM
1974 914 2.0 Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains |
After sitting overnight with the windows up I recently detected a faint gas smell inside the car. Everything looks dry topside in the front trunk, nothing wet or excessively gassy under the dash, and under the car is dry. Any ideas where to look? I have no idea if the gas line has ever been replaced and wouldn't know how to do it. Any suggestions would be great.
Loving my summer daily driver in Montana. |
Shadowfax |
Aug 15 2018, 06:08 PM
Show us the meaning of haste Group: Members Posts: 509 Joined: 19-January 15 Member No.: 18,340 Region Association: South East States |
Probably time to replace the plastic fuel lines in the tunnel and also any soft fuel lines in the engine bay and on the fuel tank. Also check the gas cap gasket. I got stainless lines for the tunnel from Tangerine Racing.
wndsrfr |
Aug 15 2018, 07:06 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Gas cap gasket likely dried out....very common.
mepstein |
Aug 15 2018, 07:16 PM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Coondog |
Aug 15 2018, 09:34 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Be safe, change every fuel line, and gasket
dgraves |
Aug 15 2018, 09:57 PM
maf914 |
Aug 16 2018, 05:49 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Gas cap gasket likely dried out....very common. Check the gas cap. Then check that the filler neck/vapor expansion tank assembly on top of the fuel tank is tightly bolted to the tank. I have had gas seep from this area on my 76 in the past. The small hex head bolts holding this can be tough to access. Thin wall sockets will help. |
Mikey914 |
Aug 16 2018, 10:13 PM
The rubber man Group: Members Posts: 12,652 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Surprisingly its more probable its a rubber line yhan the plastic.with the ethanol in the fuel being increased I had fuel lunes (rubber) fail on 2 cars this year.
76-914 |
Aug 17 2018, 08:19 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Surprisingly its more probable its a rubber line yhan the plastic.with the ethanol in the fuel being increased I had fuel lunes (rubber) fail on 2 cars this year. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 5th May 2024 - 01:04 PM |
