Replacement metal for area beneath battery tray?, Have body shop fabricate it? |
Alfred |
Jul 13 2003, 03:19 PM
Unregistered |
Has anyone done rust repairs to the metal panel that the battery tray support is welded to? Restoration Design doesn't seem to make this "ramp" like part in between #330 and #319 in this picture.
Alfred (IMG:http://www.restoration-design.com/images/ss_914_319/01_914_319.jpg) |
MarkV |
Jul 13 2003, 03:27 PM
330 looks like this, it has some of the "ramp" as part of it. The piece between 330 & the engine shelf (319) is the top of the suspension console.
Bleyseng |
Jul 13 2003, 03:41 PM
If the top of the console is gone you will have to make it yourself.
Geoff |
Alfred |
Jul 13 2003, 03:51 PM
Unregistered |
Thanks. Odd that Restoration Design doesn't make this part. I have #319 and #330 here and I'm waiting for the battery tray and support and the lower, inner wheel-house. I could also use the part of the firewall where the top of the console meets it, but RD doesn't make that part either. Mittelmotor wants big bucks for a complete wheel house.
Alfred |
Bleyseng |
Jul 13 2003, 04:39 PM
I just chopped up a old fender and shaped it into the right shape, cut it to fit the trimmed hole and welded it in.
Geoff |
EdwardBlume |
Jul 14 2003, 12:06 AM
I've had two cars repaired in this area. One was cut out of a donor car and welded in from the passenger seat back to the control arm mount. The second had the area welded with new metal. You may want to use a good shop or weld additional area because the corrosion around the battery may not be the best metal to weld.
Lo-Fi Version | Time is now: 3rd May 2024 - 09:24 AM |
