Rear fender foam, replace or other? |
bbrock |
Aug 19 2018, 09:18 AM
I know this has been discussed before but wonder what current consensus it. I stripped out the seam sealer and urethane foam that fills the cavity near the tail lights at the rear of the quarter panels yesterday. Happy to say everything looks pristine inside. That cavity looks like a serious mud catcher and given that there are 3 miles of dirt road between my house and pavement, I'm not comfortable leaving it open. I'm thinking of filling it with Evercoat Sealant Foam after epoxy primer and then sealing like the factory did. Any better options?
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.evercoat.com-20845-1534691900.1.jpg) |
cary |
Aug 19 2018, 09:21 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
914 Rubber fender liners ..........
mepstein |
Aug 19 2018, 09:40 AM
914-6 GT in waiting Group: Members Posts: 19,256 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Foam is what caused so much rust in our cars. I would never replace it. I would undercoat like the rest of the pan.
Tom_T |
Aug 19 2018, 10:11 AM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Prime & paint before anything, & IMHO Zinc Rich Primer to serve as sacrificial metal with epoxy primer over - all materials of top quality, e.g.: Dupont, PPG, Glasurit, Sekkunds, etc. (Wurth & Eastwood make good zinc primer).
Then whatever Eastwood or other top brand cavity filler/sealer, undercoating, etc. - or maybe the 914Rubber fender liners (I'm not familiar with those). (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
TravisNeff |
Aug 19 2018, 10:12 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I would leave that foam junk out and not look back. Sprayable seam sealer may be an option too.
Valy |
Aug 19 2018, 10:31 PM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Prime & paint before anything, & IMHO Zinc Rich Primer to serve as sacrificial metal with epoxy primer over - all materials of top quality, e.g.: Dupont, PPG, Glasurit, Sekkunds, etc. (Wurth & Eastwood make good zinc primer). Then whatever Eastwood or other top brand cavity filler/sealer, undercoating, etc. - or maybe the 914Rubber fender liners (I'm not familiar with those). (IMG:style_emoticons/default/beerchug.gif) Tom /////// Not an expert but painting epoxy over the zinc primer is a waste of the zinc primer. The idea of the zinc primer is that it corrodes instead of the iron but it must be in contact with the air (oxigen) to do that. |
Bartlett 914 |
Aug 20 2018, 05:59 AM
Advanced Member Group: Members Posts: 2,214 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I have not seen the liners from 914 Rubber. I got mine Jay years ago. Jay has long since passed away. Liners is the answer. They protect the tail light area as well as the door jam and the sail panel. Mine remained perfect for many years until I lost the car. I saved them and they are on my car now. Best investment without doubt. Do protect the metal as others have suggested with paint or epoxy etc just no foam!
bbrock |
Aug 20 2018, 08:43 AM
Thanks all. I'm liking those liners. I think those would be a very good idea here.
I share everyone's aversion to the foam, but in this particular cavity, I cannot say the factory was wrong. I don't know how many have poked around in that spot, but this area forms narrow cavities that extend back about 8 inches to the rear corners of the car. You might be able to get away with leaving them open in a mild climate driving only on paved roads, but in my situation, I can guarantee they will soon fill with dirt and crud to form a moisture trap way worse than the foam with seam sealer ever presented. I live 3 miles down a dirt road so every trip will include a minimum of 6 miles of dust swirling around under the fenders and settling into those cavities where it would be difficult to impossible to clean out. I think the fender liners will help reduce, but not eliminate that. And if the swirling dust isn't enough, the cavities are the perfect size for mason bees and wasps to pack with mud tubes for their nests. I'm convinced that not closing that cavity would be a mistake. My question is more about what is the best way to close the cavity than about whether to close it. The next question is how best to close it. The factory filled the cavity with foam to provide a backing for seam sealer which was applied over the foam. This worked fine until the sealer dried out, shrank, and cracked to let moisture in where it got trapped by the foam. This was one of the few areas that wasn't rusted on my car, so it worked for 40 years. I've gotta believe that sealer, and maybe foam has improved over the years since these cars were built. Right now, I can think of a couple ways to close the cavity. One is to just replicate what the factory did with modern foam and sealer. Then add inspecting the sealer in that area to my annual maintenance schedule. The other is to cut a plastic disc to block off the opening and form a backer for applying sealer, then drill a small weep hole after the sealer has cured. That would leave the cavity hollow inside but prevent crap from getting inside. I'm kinda liking this second option but need to think about it more. Before closing, I will treat the inside of the cavity with phosphoric acid and then prime and seal with PPG's top of the line DP epoxy. The tech sheet says phosphoric acid treatment can promote adhesion, but anything else under the primer could be counter productive. I'm debating whether to spray Raptor inside the cavity before closing it up. |
Bartlett 914 |
Aug 20 2018, 08:59 AM
Thanks all. I'm liking those liners. I think those would be a very good idea here. I share everyone's aversion to the foam, but in this particular cavity, I cannot say the factory was wrong. I don't know how many have poked around in that spot, but this area forms narrow cavities that extend back about 8 inches to the rear corners of the car. You might be able to get away with leaving them open in a mild climate driving only on paved roads, but in my situation, I can guarantee they will soon fill with dirt and crud to form a moisture trap way worse than the foam with seam sealer ever presented. I live 3 miles down a dirt road so every trip will include a minimum of 6 miles of dust swirling around under the fenders and settling into those cavities where it would be difficult to impossible to clean out. I think the fender liners will help reduce, but not eliminate that. And if the swirling dust isn't enough, the cavities are the perfect size for mason bees and wasps to pack with mud tubes for their nests. I'm convinced that not closing that cavity would be a mistake. My question is more about what is the best way to close the cavity than about whether to close it. The next question is how best to close it. The factory filled the cavity with foam to provide a backing for seam sealer which was applied over the foam. This worked fine until the sealer dried out, shrank, and cracked to let moisture in where it got trapped by the foam. This was one of the few areas that wasn't rusted on my car, so it worked for 40 years. I've gotta believe that sealer, and maybe foam has improved over the years since these cars were built. Right now, I can think of a couple ways to close the cavity. One is to just replicate what the factory did with modern foam and sealer. Then add inspecting the sealer in that area to my annual maintenance schedule. The other is to cut a plastic disc to block off the opening and form a backer for applying sealer, then drill a small weep hole after the sealer has cured. That would leave the cavity hollow inside but prevent crap from getting inside. I'm kinda liking this second option but need to think about it more. Before closing, I will treat the inside of the cavity with phosphoric acid and then prime and seal with PPG's top of the line DP epoxy. The tech sheet says phosphoric acid treatment can promote adhesion, but anything else under the primer could be counter productive. I'm debating whether to spray Raptor inside the cavity before closing it up. Brent. My car had them for more than 10 years and I only had liners. I really drove my car a lot. Cross country etc. When we cut up the car it was still perfect. I have the quarters upstairs and I can show pictures if interested. The liners do stop the crap and Bees will not nest there |
bbrock |
Aug 20 2018, 09:38 AM
Thanks Mark! I think I'll order a set before making any final decisions (still plenty of time). Sounds like they seal that area better than I thought. I wonder how well bed liner would stick to them. Would be nice to spray them to match the rest of the underbelly.
Bartlett 914 |
Aug 20 2018, 09:49 AM
Thanks Mark! I think I'll order a set before making any final decisions (still plenty of time). Sounds like they seal that area better than I thought. I wonder how well bed liner would stick to them. Would be nice to spray them to match the rest of the underbelly. It is PVC plastic. I would not attempt to fully seal them in place. Some moisture probably gets in there and allowing them to vent around the edges is probably best. I am not sure how 914 Rubber liners install. Mine use clips at the bottom and they snap in place. |
bbrock |
Aug 20 2018, 09:54 AM
Thanks Mark! I think I'll order a set before making any final decisions (still plenty of time). Sounds like they seal that area better than I thought. I wonder how well bed liner would stick to them. Would be nice to spray them to match the rest of the underbelly. It is PVC plastic. I would not attempt to fully seal them in place. Some moisture probably gets in there and allowing them to vent around the edges is probably best. I am not sure how 914 Rubber liners install. Mine use clips at the bottom and they snap in place. Agreed. I was thinking about spraying them with tinted Raptor before installing so they match the wheel wells but not to seal them in place. Looks like the 914rubber liners attach the same way. |
mlindner |
Aug 20 2018, 09:55 AM
Senior Member Group: Members Posts: 1,518 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
mlindner |
Aug 20 2018, 10:16 AM
Not ABS but Polyethylene plastic, comes in rolls 22 inch wide x 10 FT and is 1/8th thick. Great product for fender liners, splitter, inner door cards etc.
Lo-Fi Version | Time is now: 8th May 2024 - 01:17 AM |
