Saving Babydoll |
Saving Babydoll |
zymurgist |
Jun 15 2005, 05:19 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
I'm trying to help out a friend here. She has had a 914 for a few years now... she bought the car as a weekend toy. Never mind the fact that it was almost 30 years old, since she has a few Porsche freaks... erm, I mean friends... to help her out with maintenance.
Babydoll, as her white '74 2.0 is affectionately known, sadly has rust in all the usual places. But we're not going to go there, at least not in the immediate future. What I'm trying to do is to get the mechanicals in good shape so the car can be used as a weekend joyrider. The engine was rebuilt a few years ago with Euro pistons & cylinders, and it runs as smoothly as you can expect from a 4-banger. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) It started with an oil leak onto the clutch. Normally this is a "drop the engine, fix the problem, put it back in" kind of deal, but since we're doing this in my 2-bay garage, and I already have 2 toys of my own in it, we have to play a logistics game. We dropped the engine/tranny and rolled the car out of the garage, allowing my poor sick 911 to be coaxed back under cover. Babydoll got a car cover and then a plastic tarp to keep the rain off. So now her 2.0 drivetrain is sitting on my floor, and I'm going over it, trying to make sure that the hoses are in good shape because she has complained of chronic fuel leaks. Lo and behold, I found that all of the injection hose is 5/16" hose that is clearly marked as 7.93 mm... factory spec is 7 mm, so this hose is almost 1mm too large. There is one piece of 7mm hose, but it looks really really old, so all that hose has to go! I'm also going to replace all the worm type clamps with proper fuel injection clamps. Also going to pull the injectors and have them checked out. When they go back in they will get new seals. That, I think, should fix any fuel leaks on the engine. The emissions hose is all there, but I'd like to replace it if I can find a nice factory-type sheathed hose in 13mm, although 1/2" would be OK if it's got that sheath on the outside. The only thing missing is the deceleration valve, but my research indicates that this isn't strictly necessary. No emissions on antique cars in Virginia. When I get around to separating the engine and tranny, I plan to clean the heck out of the flywheel and pressure plate; replace the flywheel seal and O-ring; replace the clutch disc and throwout bearing; and check the oil galley plugs and goop them up if necessary. Does this sound like a good plan? Are there any "while I'm in there" things that I should attend to? I don't want to have to drop her engine for a long time, especially since I may be dropping my 911 engine (to fix oil leaks, why else?) this winter. Oh yeah... I consider engine drops and reinstalls to be 2 person jobs, so I schedule that work when my friend can come over and help me. That way somebody can call 911 (EMS, that is, not my car!) when I drop an engine on my foot. |
Verruckt |
Jun 15 2005, 05:45 AM
Senior Member Group: Members Posts: 716 Joined: 14-July 04 From: Midwest Member No.: 2,348 |
While the engine is out... I would fix that rust. Putting it off until "later" could be asking for trouble. Or allow it to get to a point where safety is a concern. Or even past the point of no return as far as saving the tub. Might as well do while the engine is out. "while you're in there..." (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
zymurgist |
Jun 15 2005, 06:07 AM
Not an option at this time. I have a sick 911 of my own that needs attention (busted shift rod), and a Corvette that I want to make some mods on (but won't take the car down unless the 911 is roadworthy, that way I have a toy of my own)... and I don't really know much about welding anyway (as in, I've seen other people do it but never done it myself).
My friend is on a fairly strict budget... that's why I'm doing the work rather than a professional, and I'm doing it on a "when I can get to it" basis. But hey, if I do end up fixing the rust, we'll already have experience dropping the powertrain and we'll be able to drop it in less than a full Saturday. |
xsboost90 |
Jun 15 2005, 06:27 AM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
roll the car onto a tarp, buy a $30 can of POR15 and a .50 paintbrush. Tell your friend to "paint" all of the rust she can see. That would at least buy her some time.
solex |
Jun 15 2005, 06:49 AM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
This may also be a good time to replace the trans main seal
mudfoot76 |
Jun 15 2005, 06:57 AM
Currently teenerless :-( Group: Members Posts: 946 Joined: 18-March 04 From: Carmel, IN Member No.: 1,814 Region Association: None |
If you feel like you can resist the "as long as we're doing this, why not [...]" (aka DWD), perhaps drill and tap the oil galley plugs. It appears you know your way around an engine, so it shouldn't take too much time. Good preventative work to ward off catastrophic oil loss.
redshift |
Jun 15 2005, 07:01 AM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
(IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) 911? Ok, get a torch, and 5 gallons of gas, and roll the 911 out into the street, and let's set it ablaze. I can't BELIEVE!!!! you come in the 914 club wearing that mink 911 around your neck! We are sensitive to the equal rights of 914s. Shift rod? Shift rod!? MY GOD MAN! As a long-time 914 driver, I can say I have driven a 914 WITHOUT ONE! (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) So... before you go getting all.... 'whatever!' on me.. please... it's a 914.. betta reco'nize! (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) So, when are you burning the 911 for insurance, so we can put a 3.8/6 in that full restoration you are gonna do on babydoll? (IMG:http://www.914world.com/bbs2/html/emoticons/beer3.gif) Miles |
rick 918-S |
Jun 15 2005, 07:02 AM
Hey nice rack! -Celette Group: Members Posts: 20,460 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) |
DNHunt |
Jun 15 2005, 07:12 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Ken
You be careful when you work on that car. 914's carry a disease called Dirk Wright Disease. Once infected you will look at a car differently. Everytime you start a project you will see other things that could be done. A newly infected individual will be heard saying "While I'm in there" and ussually the projects never end. Cars spend years on jackstands. It would be ashamed if your 911 and Corvette got the disease too. Having said that, adjust the valves while the engine is out. Big time saver. While you are in there change the valve cover gaskets. Consider replacing plugs, points, rotor and cap. But while you are in there, consider looking at the distributor cause the bushings may be worn. Change the filters. While you are in there if there is rust in the fuel filter consider pulling the fuel tank and cleaning and sealing it. Repack the CV joints or better yet while you are in there clean and inspect them and replace if necessary. (Sorry that part is NLA so you can consider adapting something else). Well crap, since we are doing all of that maybe we should do the rust. See where it can go. Seriously, check to see if it is safe (Brakes, tires, suspension and reasonably solid, fuel lines). Do a tune up (adjust valves, filters, ignition components). Eliminate vacuum leaks (new hoses). Most of this you were already on. Just don't look to close at everything else cause you may be opening a can of worms . Oh ya, JP says magic smoke lives in these cars somewhere so be really careful not to let it out cause the car never runs right without it. It sounds like you are a kind soul so tell your friend about the other things you see but, let her get them done cause you may not get back to your own cars. Dave |
Bleyseng |
Jun 15 2005, 08:01 AM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I ain't saying nuthin! (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
scotty914 |
Jun 15 2005, 08:42 AM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
hagerstown, i am 1 hour away in baltimore
and i would at least jb weld the galley plugs if you dont tap them. btw i know the wiring, the ljet fi, and how to weld |
zymurgist |
Jun 15 2005, 08:49 AM
Not burning the 911! Ain't gonna happen,no way, no how! Now, if you think I wouldn't strip the 911 for parts and sell the lightweight no-sunroof tub, you might want to think again. The engine in that car is worth what I paid for the whole car (and if you ever saw the car on the inside, you'd probably agree (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) ). I've been thinking in the back of my mind that the screaming MFI motor would totally rule in a 914. I'd also take the 5-lug brakes off the 911 and anything else that would be useful for a 914/6 project. That project ain't gonna be Babydoll, though... Babydoll isn't my car, and the owner likes the fuel economy of the 2.0, and anyway she'd kill herself in a powerful car. (She'll probably smack me upside the head if she reads this.) I'd have to find a good tub of my own, or perhaps a 914/6 project that somebody else started but couldn't finish. |
zymurgist |
Jun 15 2005, 08:59 AM
It's too late, I've already been infected. The Corvette spent 3 years on jackstands, as a project that began as an engine rebuild. - The rebuild became a replacement. - The transmission was freshened by a pro so it wouldn't break with all the new torque. - Ditto for the rear end and all U-joints in the drivetrain. (Think of a naked CV joint, more or less.) - Then, who wants to go fast if you can't stop? New calipers, brake lines, rebuilt master cylinder. - Then, who wants to go fast and brake hard if the car won't handle? New springs front and rear, suspension bushings, Konis all around. - Then, who wants to put all these new parts on a ratty looking car? Painted the engine compartment, re-wrapped the wiring harness, powder coated every bracket that would fit in my oven. After over 2 years of mucking around with this project (and there were weeks at a time when I refused to even look at it because I was so pissed off at it), I bought the 911 so I'd have a fast car to drive while my anal retentive alter-ego finished the Corvette (and you're right, they never are really finished). |
zymurgist |
Jun 15 2005, 09:06 AM
Can that be safely done? I got the impression on the Pelican 914 forum that you don't want to do this with the engine assembled. Metal shavings in the oil galleys would be a Very Bad Thing. Part of the deal with Babydoll is, I can drive it all I want until it's properly tuned, but anything I break, I have to fix. And I have no intention of tearing down the engine. Heck, I didn't even want to do that for the Corvette (that's why I bought an engine from a builder). |
zymurgist |
Jun 15 2005, 09:14 AM
Can that seal be replaced without cracking the transmission case? |
scotty914 |
Jun 15 2005, 09:28 AM
i will start in reverse
yes you can change the seal with out opening the tranny also you can tap the case with the engine together there are a few tricks like lots of grease on the tap to hold the shavings. then you put rags in the iol passages to catch any shaving that get away. as for the grease you have to pull the tap every 180 dregreas of cutting and clean it off regrease and do another 180 |
type47 |
Jun 15 2005, 10:13 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
hi ken, this is jim, babydoll's owners friend. about your question about the hoses: i have a diagram from AA about all the sizes and length requirements of all the hoses. send me your email address and i'll forward the info. i picked up new hoses for my engine at the bug out in manassas on memorial day but pelican sells lengths of all the hoses as well.
zymurgist |
Jun 15 2005, 11:08 AM
Thanks, Jim. She left a big white binder full of 914 articles at my house. If your diagram isn't already in there (there are 3 in it now), I'll add it. That's how I discovered that there was no deceleration valve.
I didn't know about the Bug Out, but then I don't follow VW stuff that much. (Maybe I should, for Babydoll's sake.) There will be an all-German swap meet in September at Ski Roundtop, PA (just our side of Harrisburg) that I'm planning on attending... also, I'm going to the Porsche Parade in Hershey on the 25th... not as a Porsche participant, but I'd like to check the swap meet and see what cool cars turn up in the display area. There was a Carrera GT there in April. (Gotta love those mid-engine roadsters!) |
zymurgist |
Jul 10 2005, 08:01 PM
OK, I have a question. Babydoll's flywheel looks pretty good, surface-wise, and has a good pilot bearing. There is an area that looks fairly chewed up, but I don't know if it's anything to be concerned about. In the recess, where the O-ring seats, the flat surface isn't very flat. Is this a problem?
zymurgist |
Jul 10 2005, 08:04 PM
Trying to post a picture.
Attached image(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 05:06 AM |
