| Mikey914 |
Aug 21 2018, 10:16 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,782 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
So, I have made hundreds of these and have many satisfied customers. I flat tow longer distances as it gives me an insurance policy that if it stops running I can always get it back home at minimal expense. It's also the only way the wife will go on the further trips. You don't even notice it's there. I leave mine on all the time. The LE airdam allows for the bracket to be accessed without removing anything.
The assembly bolts to the "frame" at the front A arm mount point and we provide the hardened steel bolts to do so as part of the kit. The LE airdam is ONLY available at $125 with the purchase of the tow bar. Brackets are optional and not required if a Empi style tow bar is not used. So, who's interested? I'll post up more pictures later today. Attached thumbnail(s) |
| Mikey914 |
Aug 21 2018, 10:25 AM
As you can see from the angle it hides pretty well.
Note that the mounts are actually rounded to act as a skid plate and that the bar is tucked up under the mount point to make it less likely you could "find" something with it. Attached thumbnail(s) |
| Mikey914 |
Aug 21 2018, 01:11 PM
Just to be clear I need 10 takers to offer this up.
| relentless |
Aug 21 2018, 03:06 PM
Member ![]() ![]() Group: Members Posts: 352 Joined: 1-April 07 From: Oregon Member No.: 7,636 |
Mark, what else is needed to connect to the tow vehicle?
| Mikey914 |
Aug 21 2018, 03:40 PM
Currently the VW beetle tow bar that is available on Amazon and other places as well as the tow lights from harbor freight. They often go on sale for $10. Don't bother with LED as I've had my reg ones for 5 years.
The improvement we are working on will add $26 but will allow for use of the cheaper tow bar. often on sale for about $69. https://www.harborfreight.com/5000-lb-capac...-bar-94696.html 20% of coupons help Here's one for $39.99 https://www.ruralking.com/tow-bar-adjustbl-...ASABEgKgFvD_BwE The lights are here - https://www.ruralking.com/max-load-12v-mag-...BSABEgKAuPD_BwE and here https://www.harborfreight.com/12-volt-magne...-kit-63100.html |
| Grafiks |
Aug 22 2018, 04:22 AM
Newbie ![]() Group: Members Posts: 8 Joined: 4-February 18 From: Banner Elk, NC Member No.: 21,863 Region Association: None |
So, I have made hundreds of these and have many satisfied customers. I flat tow longer distances as it gives me an insurance policy that if it stops running I can always get it back home at minimal expense. It's also the only way the wife will go on the further trips. You don't even notice it's there. I leave mine on all the time. The LE airdam allows for the bracket to be accessed without removing anything. The assembly bolts to the "frame" at the front A arm mount point and we provide the hardened steel bolts to do so as part of the kit. The LE airdam is ONLY available at $99 with the purchase of the tow bar. So, who's interested? I'll post up more pictures later today. Bob Hodgin Grafiks |
| Grafiks |
Aug 22 2018, 04:25 AM
Will buy
Grafiks Bob Hodgin Banner Elk, NC |
| Rleog |
Aug 22 2018, 05:30 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 611 Joined: 12-October 03 From: Middleton, MA Member No.: 1,239 Region Association: North East States
I'm not familiar with general towing laws. How much weight can you legally tow without having brakes on the towed vehicle/trailer actuated by the towing vehicle?
| Mikey914 |
Aug 22 2018, 07:06 AM
may vary in different states, but 3000# is the only thing I've ever seen.
| PanelBilly |
Aug 22 2018, 10:48 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,969 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
I want the new bar that works with the HF tow bar. I’ve been trying to figure out how to modify my brand new bar that I still haven’t installed because it doesn’t connect with the HF unit. Can I trade you if I pay for a new spoiler too?
| Mikey914 |
Aug 22 2018, 11:10 AM
Actuall it's an add on so you will just need the new adapter.
| markhoward |
Aug 22 2018, 11:43 AM
Member ![]() ![]() Group: Members Posts: 406 Joined: 5-March 17 From: Lafayette, CA Member No.: 20,897 Region Association: Northern California
Would like to get in on an LE air dam deal but already bought your flat tow bar last year.
| iankarr |
Aug 22 2018, 02:09 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,600 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
Thanks for this, Mark! I'm in for the bar and LE airdam...
Ian |
| PanelBilly |
Aug 22 2018, 03:10 PM
| pilothyer |
Aug 22 2018, 04:32 PM
Member ![]() ![]() ![]() Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Mark...…….Looks like an excellent idea. I would be up for the package....Jerry
| Mikey914 |
Aug 22 2018, 06:19 PM
| KELTY360 |
Aug 22 2018, 06:49 PM
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,189 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest
I'm looking at options to tow my 914 behind my SVX Westy. What's the difference between this one and the one @914Werke has in the Member Vendor section?
Flat tow bar |
| Mikey914 |
Aug 22 2018, 09:04 PM
His is a diferent design. Functionally woud be simular. Im just not a fan of the amgle bracket.
Other than that mine you used to have to buy the super beetle tow bar for mine. With the new adapter, you will be able to use a tow bar that is less expensive and you could pick up localky to save shipping on a heavy part. |
| relentless |
Aug 23 2018, 05:14 PM
Mark, will the air dam work on a BUB car?
| 914werke |
Aug 23 2018, 06:38 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,680 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
His is a diferent design. Functionally woud be simular. Im just not a fan of the amgle bracket. Other than that mine you used to have to buy the super beetle tow bar for mine. With the new adapter, you will be able to use a tow bar that is less expensive and you could pick up localky to save shipping on a heavy part. Cool (IMG:style_emoticons/default/piratenanner.gif) I just got a "notification" that I was tagged & could follow the embedded link to this thread. Thanks Andy! To address the question Kelty posed... While I dont understand what your issue is with the use of an angle on the construction of my bracket, it looks like you are now intending to adapt your bracket to mimic the function (& price) of one that is already available! HERE I guess imitation "is" the sincerest form of flattery. |
Lo-Fi Version | Time is now: 14th June 2026 - 06:33 PM |
