GB tow bar for flat towing $99 Universal Tow bar mounts $25, $125 special on LE airdams w/ GB It's ON OPEN til 11/1/20 |
Mikey914 |
Aug 21 2018, 10:16 AM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So, I have made hundreds of these and have many satisfied customers. I flat tow longer distances as it gives me an insurance policy that if it stops running I can always get it back home at minimal expense. It's also the only way the wife will go on the further trips. You don't even notice it's there. I leave mine on all the time. The LE airdam allows for the bracket to be accessed without removing anything.
The assembly bolts to the "frame" at the front A arm mount point and we provide the hardened steel bolts to do so as part of the kit. The LE airdam is ONLY available at $125 with the purchase of the tow bar. Brackets are optional and not required if a Empi style tow bar is not used. So, who's interested? I'll post up more pictures later today. Attached thumbnail(s) |
914forme |
Sep 1 2018, 10:11 AM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
(IMG:style_emoticons/default/agree.gif) These look closer to the old Renn-metal products. He made one with his trailer tie down brackets on the front that I have been thinking of duplicating. I love his tie downs on the front, the rear is a different story, but I just welded my one set to the arm.
The design error was not due to his design I used it for my own rear swayer mount for the rear drop links. I prefer to tie down via the chassis and keep suspension movement to a minimum. I have wheel wraps, suspension wraps. But just hooking to the tie downs was fast and easy and reduced the unintended mileage added to the shocks. I may be crazy. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 26th May 2024 - 02:38 AM |
