GB tow bar for flat towing $99 Universal Tow bar mounts $25, $125 special on LE airdams w/ GB It's ON OPEN til 11/1/20 |
Mikey914 |
Aug 21 2018, 10:16 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So, I have made hundreds of these and have many satisfied customers. I flat tow longer distances as it gives me an insurance policy that if it stops running I can always get it back home at minimal expense. It's also the only way the wife will go on the further trips. You don't even notice it's there. I leave mine on all the time. The LE airdam allows for the bracket to be accessed without removing anything.
The assembly bolts to the "frame" at the front A arm mount point and we provide the hardened steel bolts to do so as part of the kit. The LE airdam is ONLY available at $125 with the purchase of the tow bar. Brackets are optional and not required if a Empi style tow bar is not used. So, who's interested? I'll post up more pictures later today. Attached thumbnail(s) |
Mikey914 |
Sep 20 2018, 11:16 AM
Matt is planning on being there. I can send him with some stuff. We have all the hardware you need to change out (as the 3/8" steel adds length to the requirement for the hardware, as well as spacer tubes for the front bolts.
One thing that hasn't been mentioned is that we include the mounting hardware you need to install these so you will not need to make a trip to the hardware store looking for bolts. If your front end has any tweaked you can add a washer or two. |
Lo-Fi Version | Time is now: 18th May 2024 - 07:29 PM |
