GB tow bar for flat towing $99 Universal Tow bar mounts $25, $125 special on LE airdams w/ GB It's ON OPEN til 11/1/20 |
Mikey914 |
Aug 21 2018, 10:16 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So, I have made hundreds of these and have many satisfied customers. I flat tow longer distances as it gives me an insurance policy that if it stops running I can always get it back home at minimal expense. It's also the only way the wife will go on the further trips. You don't even notice it's there. I leave mine on all the time. The LE airdam allows for the bracket to be accessed without removing anything.
The assembly bolts to the "frame" at the front A arm mount point and we provide the hardened steel bolts to do so as part of the kit. The LE airdam is ONLY available at $125 with the purchase of the tow bar. Brackets are optional and not required if a Empi style tow bar is not used. So, who's interested? I'll post up more pictures later today. Attached thumbnail(s) |
Mikey914 |
Oct 18 2018, 09:00 AM
Actually the HF end needs to be removed and the new part replaces it. I'll see if I can drop a pic shortly. It can use the bolt and nut that attaches the HF end piece that it comes with. I made them so you didn't have to go buy hardware.
Mark |
HansJan |
Oct 18 2018, 11:11 AM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Actually the HF end needs to be removed and the new part replaces it. I'll see if I can drop a pic shortly. It can use the bolt and nut that attaches the HF end piece that it comes with. I made them so you didn't have to go buy hardware. Mark Thanks for the reply Mark, Scott mentioned that I accidentally received some parts that were meant to be scrapped, and that the correct parts are being mailed. I never gave it a thought. Our friends on in this community, with 20/20 vision, pointed it out. Thanks for looking after me guys. |
Lo-Fi Version | Time is now: 18th May 2024 - 07:51 PM |
