GB tow bar for flat towing $99 Universal Tow bar mounts $25, $125 special on LE airdams w/ GB It's ON OPEN til 11/1/20 |
Mikey914 |
Aug 21 2018, 10:16 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So, I have made hundreds of these and have many satisfied customers. I flat tow longer distances as it gives me an insurance policy that if it stops running I can always get it back home at minimal expense. It's also the only way the wife will go on the further trips. You don't even notice it's there. I leave mine on all the time. The LE airdam allows for the bracket to be accessed without removing anything.
The assembly bolts to the "frame" at the front A arm mount point and we provide the hardened steel bolts to do so as part of the kit. The LE airdam is ONLY available at $125 with the purchase of the tow bar. Brackets are optional and not required if a Empi style tow bar is not used. So, who's interested? I'll post up more pictures later today. Attached thumbnail(s) |
Mikey914 |
Sep 20 2020, 10:54 AM
If you bought my bar you might need the adaptors. You can see the end that I took off that would allow a bolt to go through. The adaptors are shown attached to the Walmart bar.
You should take a look and see what you have as the bars I made were designed for the Empi tow bar. Post up a pic of what you have I can let you know. Mark |
Lo-Fi Version | Time is now: 18th May 2024 - 08:58 PM |
