Broke my shifter coupler, any write ups to correctly R&R? |
Mueller |
Aug 31 2018, 01:10 PM
Luckily I have a brand new flex joint, I just don't want break it again.
bdstone914 |
Aug 31 2018, 01:31 PM
ClayPerrine |
Aug 31 2018, 03:50 PM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
You can always replace it with a steering U-Joint. Easy to uncouple, and never requires new bushings.
Plus, what you need is probably already in your parts stash. |
Bartlett 914 |
Sep 1 2018, 10:24 AM
Luckily I have a brand new flex joint, I just don't want break it again. Call me at 951 536 seven for seven ate and I can walk you through the non destructive R & R. When driving out the pin, it is important that you don't drive against the aluminum. You must support the square part of the shift rod. Do not lay horizontal on the aluminum coupling. The pin is press fitted in the steel so this is where support must placed |
914forme |
Sep 1 2018, 11:05 AM
You can always replace it with a steering U-Joint. Easy to uncouple, and never requires new bushings. Plus, what you need is probably already in your parts stash. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 04:04 PM |
