Tranmission issue, no going into any gear |
Localboy808 |
Aug 31 2018, 05:06 PM
Member Group: Members Posts: 185 Joined: 17-July 16 From: Palmdale, Ca Member No.: 20,194 Region Association: None |
I'm hoping someone can give me a suggestion are where to start. Installed my motor and trans finally. Trans has been sitting in the garage for over a year. Was working fine before I pulled it. Only thing I changed was the clutch disc. I got the rear wheels off the ground and pit it into second gear to get TDC to install my distributor and found that no matter what gear I put it in I could not get it to engage. even though the shifter feels like its shifting its like its staying in neutral. Pulled the trans and annually moving the shifter linkage does the same thing. Its a tail shift trans by the way. What am I missing here? So close to getting this back on the road. Took the wind out of my sails this morning!
Thanks! Scott |
Aug 31 2018, 05:09 PM
Clutch cable adjustment?
theer |
Aug 31 2018, 05:15 PM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Cone screw missing somewhere along the line - linkage not engaging trans shaft?
worn |
Aug 31 2018, 06:54 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Cone screw missing somewhere along the line - linkage not engaging trans shaft? No, he says it is the same manually shifting with it out. Trying to imagine how that would be happening (IMG:style_emoticons/default/popcorn[1].gif) |
worn |
Aug 31 2018, 06:55 PM
Cone screw missing somewhere along the line - linkage not engaging trans shaft? No, he says it is the same manually shifting with it out. Trying to imagine how that would be happening (IMG:style_emoticons/default/popcorn[1].gif) Shifter forks not tightened? |
Localboy808 |
Aug 31 2018, 09:19 PM
Correct, same problem after pulling the trans. I can manually shift through gears and hear it click. But then when you turn the hubs or shafts the main shaft doesn't spin. i tried manually spinning the main shaft and then it started to want to turn with the axles. Then it stopped. I'm pretty ignorant when it comes to the inner workings of these transmissions. Could something be gummed up in there from sitting for a year?
mgphoto |
Sep 1 2018, 05:05 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
You have to immobilize one of the wheels to be able to spin the main shaft, unless you have a limited slip diff.
mb911 |
Sep 1 2018, 05:09 PM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
worn |
Sep 1 2018, 05:16 PM
Localboy808 |
Sep 1 2018, 07:40 PM
OMG did I just pull the trans for nothing? (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) I'll try that in the morning.
bobboinski |
Sep 1 2018, 08:50 PM
Member Group: Members Posts: 198 Joined: 23-April 16 From: Petaluma Member No.: 19,929 Region Association: Northern California |
OMG did I just pull the trans for nothing? (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) I'll try that in the morning. If the trans is pulled try turning the input shaft while in a gear. One output should turn. If it does it seems to me things should be ok. |
Localboy808 |
Sep 1 2018, 10:53 PM
OMG did I just pull the trans for nothing? (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) I'll try that in the morning. If the trans is pulled try turning the input shaft while in a gear. One output should turn. If it does it seems to me things should be ok. Yeah. I tried it. It's fine. OMG. Not one of my finer moments. Thanks for the help guys. |
bobboinski |
Sep 2 2018, 06:39 PM
OMG did I just pull the trans for nothing? (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) I'll try that in the morning. If the trans is pulled try turning the input shaft while in a gear. One output should turn. If it does it seems to me things should be ok. Yeah. I tried it. It's fine. OMG. Not one of my finer moments. Thanks for the help guys. Glad it's ok. I gave up trying to be perfect about 60 yrs. ago. I'm 61. (IMG:style_emoticons/default/beerchug.gif) |
Localboy808 |
Sep 2 2018, 09:09 PM
OMG did I just pull the trans for nothing? (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) I'll try that in the morning. If the trans is pulled try turning the input shaft while in a gear. One output should turn. If it does it seems to me things should be ok. Yeah. I tried it. It's fine. OMG. Not one of my finer moments. Thanks for the help guys. Glad it's ok. I gave up trying to be perfect about 60 yrs. ago. I'm 61. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 03:16 PM |
