I'm hoping someone can give me a suggestion are where to start. Installed my motor and trans finally. Trans has been sitting in the garage for over a year. Was working fine before I pulled it. Only thing I changed was the clutch disc. I got the rear wheels off the ground and pit it into second gear to get TDC to install my distributor and found that no matter what gear I put it in I could not get it to engage. even though the shifter feels like its shifting its like its staying in neutral. Pulled the trans and annually moving the shifter linkage does the same thing. Its a tail shift trans by the way. What am I missing here? So close to getting this back on the road. Took the wind out of my sails this morning!
Thanks! Scott
