> sway bars
914andy
post Sep 1 2018, 05:00 PM
Hi all
I have what I believe is a "charley Bar" front 22mm sway bar. The bar itself is splined and the short arms are splined to match.
Any way, I'm looking for some bushings.
Any leads appreciated.
andyAttached Image
mgphoto
post Sep 1 2018, 05:17 PM
"If there is a mistake it will find me"
Porsche dealers have them, used on 911’s.
bdstone914
post Sep 1 2018, 09:17 PM
bdstone914
QUOTE(mgphoto @ Sep 1 2018, 04:17 PM) *
I don't think you will find then in 19mm with Porsche. Stock were 15mm. Those pictured are polygraphite.
post Sep 1 2018, 09:29 PM
914-6 GT in waiting
I think you want part # 90134379204 Early 911 turbo
bdstone914
post Sep 2 2018, 07:43 AM
bdstone914
QUOTE(mepstein @ Sep 1 2018, 08:29 PM) *
That shows to be a 18mm bushing. Not sure it will would for a 19mm bar. Might be able to make it work by grinding the inside with an abrasive drum bit. Seems to come without a slit.
914andy
post Sep 2 2018, 09:23 AM
forgot to say that the bushings I have are some sort of hard
material. They are not rubber.
andy
914werke
post Sep 2 2018, 12:03 PM
Get the rubber vers & put a slit in it.
bdstone914
post Sep 2 2018, 01:02 PM
bdstone914
QUOTE(914werke @ Sep 2 2018, 11:03 AM) *
I see that he has a 21mm bar so I wonder if the wall thickness of the bushing for the 18 mm will be too thick.
914forme
post Sep 2 2018, 03:57 PM
have them machined out of Delrin (IMG:style_emoticons/default/confused24.gif)
RickS
post Sep 2 2018, 09:48 PM
Have them machined from Teflon. No insane squeaking like....uh...Delrin.
- Lo-Fi Version Time is now: 13th July 2025 - 10:22 AM
