Full Version: sway bars
914andy
Hi all
I have what I believe is a "charley Bar" front 22mm sway bar. The bar itself is splined and the short arms are splined to match.
Any way, I'm looking for some bushings.
Any leads appreciated.
andyClick to view attachment
mgphoto
Porsche dealers have them, used on 911’s.
bdstone914
QUOTE(mgphoto @ Sep 1 2018, 04:17 PM) *
I don't think you will find then in 19mm with Porsche. Stock were 15mm. Those pictured are polygraphite.
I think you want part # 90134379204 Early 911 turbo
bdstone914
QUOTE(mepstein @ Sep 1 2018, 08:29 PM) *
That shows to be a 18mm bushing. Not sure it will would for a 19mm bar. Might be able to make it work by grinding the inside with an abrasive drum bit. Seems to come without a slit.
914andy
forgot to say that the bushings I have are some sort of hard
material. They are not rubber.
andy
914werke
Get the rubber vers & put a slit in it.
bdstone914
QUOTE(914werke @ Sep 2 2018, 11:03 AM) *
I see that he has a 21mm bar so I wonder if the wall thickness of the bushing for the 18 mm will be too thick.
914forme
RickS
Have them machined from Teflon. No insane squeaking like....uh...Delrin.
