Brake Bleeding Problem, Master Cylinder? |
74Wheels |
Sep 3 2018, 11:45 AM
Newbie Group: Members Posts: 11 Joined: 6-July 17 From: Missouri Member No.: 21,232 Region Association: Upper MidWest |
I have my 2nd 74 2.0 and having issue with brakes. Rebuilt all 4 Calipers due to a stuck Front Caliper. Had a pretty firm pedal prior to rebuild, but could have been the stuck caliper? Anyway bleed everything yesterday per all threads I read and got a firm pedal. But then after it sat for awhile, the pedal would go almost all the way down on the first push but would then pump up on successive braking. After sitting overnight, now I have nothing today. No leaks and fluid level still where it was yesterday. Bleed about a gallon through with a power bleeder.
I’m thinking Master Cylinder now and wanted to get feedback on thoughts and what brand of Master to buy? It’s still the original 17mm Cylinder which I want to stay with. |
74Wheels |
Sep 4 2018, 06:14 AM
I spent all day Bleeding and I know the system is notorious for trapping air! I didn’t have a helper so here’s what I did: power bleed bottom and then tops in correct order. Then did a gravity drip bleed on the MC for 2hr massaging the brake a lot! Then the same on the proportioning valve. Rebleed all calipers again! It was alittle better! So I did a power bleed on the MC and proportioning valve all the while tapping on them! Then rebleed all calipers using top valves and tapping with a hammer. Still the same. So let me know what else to try. Going with a 2 man now and re Bleeding is my last try before getting a new MC.
Lo-Fi Version | Time is now: 17th May 2024 - 09:38 PM |
