Wire from AAR, Cleaning up the PO's mess |
rjames |
Sep 4 2018, 11:08 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
The white wire from the ignition harness on my car is missing the spade connector and is wrapped in electrical tape and not connected to anything. Wire looks to have broken off at some point and is pretty short. According to my searches on this site and Bowlsby's, the white wire is supposed to go to the AAR valve. However, my AAR is hooked up directly to the positive post on the coil.
What badness would this cause? BTW, I'm trying to chase down a hunting idle. AAR valve itself seems to be operating correctly (lots of suction when the car is cold, and none when warmed up). Next I'll be verifying that the TPS is set correctly. |
Bartlett 914 |
Sep 5 2018, 07:52 AM
The white wire from the ignition harness on my car is missing the spade connector and is wrapped in electrical tape and not connected to anything. Wire looks to have broken off at some point and is pretty short. According to my searches on this site and Bowlsby's, the white wire is supposed to go to the AAR valve. However, my AAR is hooked up directly to the positive post on the coil. What badness would this cause? BTW, I'm trying to chase down a hunting idle. AAR valve itself seems to be operating correctly (lots of suction when the car is cold, and none when warmed up). Next I'll be verifying that the TPS is set correctly. I don't think this will cause an issue. The AAR and the fuel pump are normally on the same circuit. |
JeffBowlsby |
Sep 5 2018, 07:58 AM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Hook it up right and fogeddaboutit.
Bartlett 914 |
Sep 5 2018, 09:06 AM
Hook it up right and fogeddaboutit. (IMG:style_emoticons/default/agree.gif) I was answering the question of how big an issue is this. I should and does work. Best advice is as Jess stated |
rjames |
Sep 5 2018, 10:02 AM
QUOTE I don't think this will cause an issue. The AAR and the fuel pump are normally on the same circuit. Good to hear. Thanks! Hook it up right and fogeddaboutit. I would love to, but it will require buying a new wiring harnesses and I don't have the funds at the moment. |
Jonathan Livesay |
Sep 5 2018, 10:20 AM
Senior Member Group: Members Posts: 741 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
QUOTE I don't think this will cause an issue. The AAR and the fuel pump are normally on the same circuit. Good to hear. Thanks! Hook it up right and fogeddaboutit. I would love to, but it will require buying a new wiring harnesses and I don't have the funds at the moment. Splice as much more wire as you need onto the white wire then crimp on a connector. Then plug it in. Actually, scratch that. Unplug the AAR wire from the coil, take the connector that was plugged to the coil off of the wire, splice that end of that wire to the white wire. Done. |
Rand |
Sep 5 2018, 10:21 AM
The hunting idle issue makes me think there's a vacuum leak. Gets too lean, hunts up, doesn't have the right fuel mixture, drops back down.
JeffBowlsby |
Sep 5 2018, 11:00 AM
QUOTE I don't think this will cause an issue. The AAR and the fuel pump are normally on the same circuit. Good to hear. Thanks! Hook it up right and fogeddaboutit. I would love to, but it will require buying a new wiring harnesses and I don't have the funds at the moment. You may be able to solder a wire on the stub that is there, or cut the harness casing open to expose 1/2 in of wire to extend. |
dr914@autoatlanta.com |
Sep 5 2018, 11:15 AM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
take it off the coil or anytime you have the switch on the aux air valve is getting power, and will eventually burn out as there is a toaster element inside of it. It also draws a lot of juice. We rebuild these all of the time, and they are just a fragile piece
The white wire from the ignition harness on my car is missing the spade connector and is wrapped in electrical tape and not connected to anything. Wire looks to have broken off at some point and is pretty short. According to my searches on this site and Bowlsby's, the white wire is supposed to go to the AAR valve. However, my AAR is hooked up directly to the positive post on the coil. What badness would this cause? BTW, I'm trying to chase down a hunting idle. AAR valve itself seems to be operating correctly (lots of suction when the car is cold, and none when warmed up). Next I'll be verifying that the TPS is set correctly. |
rjames |
Sep 5 2018, 11:38 AM
Ok, I'm convinced. I'll see if I can get it connected correctly.
Thanks for the input everyone. |
rjames |
Sep 5 2018, 11:42 AM
The hunting idle issue makes me think there's a vacuum leak. Gets too lean, hunts up, doesn't have the right fuel mixture, drops back down. Actually, it hunts down and intermittently at that. But that doesn't mean there still couldn't be a vacuum leak somewhere. The last things on my list to check: intake runner boots TPS throttle body gasket plenum |
rjames |
Sep 5 2018, 03:27 PM
Is it true that the newer TPS isn't adjustable?
Found this posted in a thread somewhere: |
JeffBowlsby |
Sep 5 2018, 03:30 PM
Those are TPS, all are adjustable by rotating about the throttle shaft. See the slotted holes?
rjames |
Sep 5 2018, 03:37 PM
Those are TPS, all are adjustable by rotating about the throttle shaft. See the slotted holes? I've read and understand the procedure for calibration, just want to make sure it applies to both models. I have the 'newer' one. According to someone's previous post the newer one isn't adjustable. Just wanted to know if that was really true before I started futzing with it. Or maybe I'm misunderstanding the post. What I'm asking is: What's different about the two versions, what can be adjusted on each one, and is the method of adjustment (calibration) the same? |
JeffBowlsby |
Sep 5 2018, 03:48 PM
Go look at your TPS, its obvious what is adjustable. The TPS for a 1975 2.0L is different than the two shown.
Lo-Fi Version | Time is now: 17th May 2024 - 06:25 PM |
