Roger's 914 thread., I could have had a V8! |
Dr. Roger |
Jun 16 2005, 12:44 AM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
In summary:
Found the car on Craigslist. Low mile, low rust, straight body. No holes in the hell hole. Longs are clean. A small miracle. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) After seeing Rick's "Alien" build, Felix's "Neo 914", and meeting "JLo", Andyrew, Sir Andy and other's rides.... I just gotta' get'er done! |
neo914-6 |
Jun 16 2005, 01:02 AM
neo life Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Kick it! Lethargy is a killer...
Dr. Roger |
Jun 16 2005, 01:03 AM
Thanks Felix,
Of course seeing your beauty coming together played a part. \BTW, where'd you have those 3" spacers made? |
neo914-6 |
Jun 16 2005, 01:13 AM
The Neo914 flares are awesome in person but now it sits under a cover until the V8 is back on the road. I thought this was a weekend bolt in but as Renegade says "these are hand built cars, you gotta MAKE things fit"... (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Wheel adapters are from Ernie's Alloys, Inc. who sells on eBay. They actually sent me a second set by accident since I had them ship to WA, not my address here. My honesty got the better of me and I sent the extra set back... (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) |
Dr. Roger |
Jun 18 2005, 11:04 AM
Attached image(s) |
Dr. Roger |
Attached image(s) |
Dr. Roger |
Jun 18 2005, 11:06 AM
....Heads assembled.
Newly rebuilt "Otto's" 901 w/H gear. First gear removed. This post has been edited by rogergrubb: Oct 1 2005, 11:51 AM Attached image(s) |
Dr. Roger |
Jun 18 2005, 11:07 AM
Attached image(s) |
Dr. Roger |
Attached image(s) |
redshift |
Jun 18 2005, 11:08 AM
Your intake manifold has more bhp than my motor.
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) M |
Dr. Roger |
Attached image(s) |
Dr. Roger |
test fit, test fit, test fit....... all good.
Attached image(s) |
Dr. Roger |
Attached image(s) |
Dr. Roger |
Jun 18 2005, 11:47 AM
ewdysar |
Jun 20 2005, 06:04 PM
What happens here, stays here. Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
Your manifold looks a little tall. You may run into trouble finding an air cleaner that will fit under the hood. Looks like you're making good progress... (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif)
Eric |
Dr. Roger |
Jun 20 2005, 06:31 PM
Yes Eric,
There will be a clearance issue. I'm going to install a cold air intake from parts from a few intake systems. Obviously the first thing is a fairly shallow rubber duct to the carb. Pulling air from I don't know exactly where yet... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
TravisNeff |
Jun 20 2005, 07:00 PM
Looking good Roger!
914GT |
Jun 20 2005, 07:57 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
A few suggestions ...
- With those headers make sure you'll be able to route your exhaust on the left side to clear your shifter bar. - Don't use the front and back rubber intake manifold gaskets and instead use a thick bead of Permatex on the rails. - Get a one-piece oil pan gasket, much better than the 4-piece sets. Worth the extra cost. - Use a double-roller timing set with a 3-keyway crank sprocket so you can advance the cam. With the cam I'm using I've found a 4 degree advance makes a big difference in performance. |
Dr. Roger |
Jun 20 2005, 11:38 PM
Hmm, i didn't know the made a one piece pan gasket. I'll check that out. Permatex? What color/type?? Which cam are you using???? I'm using the Comp Cams Extreme Energy hydraulic 294. Dyno stats below. Dyno Results Camshaft Part # 12-443-8 Designation XR294HR-10 Duration @ 0.006" 294 / 300 Duration @ 0.050" 242 / 248 Max Lift w/ 1.5RR .540 / .562 Lobe Separation 110 Lobe ID#'s 3317 / 3318 Intake Centerline 106 Engine Type Chevrolet 350 Small Block Bore 4.040" Stroke 3.480" Displacement 356 Compression 9.25:1 Heads Dart Sportsman II Intake Edelbrock Victor Jr. Carburetor Holley 750 dbl. pmp. Exhaust 1 3/4" Headers Max Torque 380 ft*lbs @ 4100 RPM Max Power 420 HP @ 6100 RPM My engine setup is almost identical to the compcams stats above except i'm using mildly ported Chevy small combustion chamber heads (9.5:1), 355cid, and i'll be breaking in the motor w/a 600 holley and street dominator intake. |
914GT |
Jun 21 2005, 10:13 AM
I use the orange Permatex but the other 'flavors' should work fine.
I'm using a Speed Pro # CS1013R 288/298 duration .050", .443/.465 lift 112 lobe sep Your cam looks to have higher lift but shorter duration. I'd be interested in how it idles. |
Lo-Fi Version | Time is now: 28th May 2024 - 01:45 AM |
