How much paint? |
How much paint? |
bbrock |
Sep 7 2018, 01:57 PM
Yeah, I know this exact question has been asked, but I didn't find enough info for what I need. It's a long shot, but I MIGHT actually get my car in primer and color on the belly... and maybe even interior this fall before winter hits (which will be soon here), so I need to get my ducks in a row in case the gods smile on my progress while the weather holds.
Local shop carries PPG but only top of the line and bottom of the line. So top of the line Deltron it is which will provide the best coverage. But I'll be spraying 3 different products plus primers and need to know how much of each to buy. So how much of each of these?
Any help appreciated. At a billion dollars/ounce, I want to make sure I get enough, but not too much. (IMG:style_emoticons/default/beerchug.gif) |
914forme |
Sep 7 2018, 02:18 PM
Your Epoxy might be low, but that is fine as you can get more if needed.
Don't forget all that extra primer you get to send off to make everything super smooth. GRM did an article on their Project 914 it is part 3, and they might have listed all the steps and supplies they used to get their 914 green. Also congratulation on getting to the point of paint. (IMG:style_emoticons/default/piratenanner.gif) or at least thinking about buying it. |
Andyrew |
Sep 7 2018, 02:19 PM
[*]Single Stage - Interior, inside trunks, and spots on belly where I don't want high build of bed liner (e.g. mount points)
Probably get away with just 1 quart. With reducer and hardner its about 1.6 quarts. You only need to do 2ish coats on the interior to get color so its less.. [*]Base/Clear - Exterior only (maybe under sides of deck lids too?) 1 quart of color would probably be enough here as well, and probably 2 quarts of clear. If I were you I would just buy a gallon kit of base/clear. You'll have plenty for screwups, and it lets you practice shooting base/clear on the interior and trunks. The last thing you want is to be spraying the body and find out you mixed a batch wrong and not have enough material to finish, or that its simply not enough. As far as primer goes, Its never enough. You could easily sand a gallon of primer off the car doing bodywork. I normally go through about 3 gallons of primer on a car that has a lot of bodywork. And there is multiple different types of that... If your spraying a factory color then ignore me, but if its a custom color I like getting my stuff through TCPglobal.com Cheap stuff that sprays out VERY nice. Consumables and tools are also very cheap. It helps if you do one big order as the shipping is EXPENSIVE. I typically get my body fillers and filler primers at my local shop but you could get that stuff on the site as well. A healthy budget on supplies is about $800 including primer/body filler/ and lots and lots of sandpaper. |
mb911 |
Sep 7 2018, 02:48 PM
914 Guru Group: Members Posts: 6,854 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Just bought paint for my sons 944 and had the paint shop whom I have known for years help determine how much paint. Went base 2 qts, clear 1gallon , sealer 1qt, allot glass on a 944 but that is a point of reference.. Cost 350 all ppg shopline.
bbrock |
Sep 7 2018, 02:59 PM
Super helpful info here guys! Many thanks. (IMG:style_emoticons/default/beer.gif)
I neglected to say that my plan is to spray the DPLF epoxy, then follow on the exterior surfaces with a few coats of high build. Then spend some quality time over the winter blocking to prep for spraying the rest of the color next summer. I don't think the DPLF is intended to be sanded except for a scuff for adhesion if you let it sit more than 2 weeks without top coating. Figured I'd have a better idea of how much surfacer to buy after spraying the primer. For color, I'm staying with the original silver metallic. Yeah, silver metallic (IMG:style_emoticons/default/ohmy.gif) . Extra paint for practice is definitely a good idea! Here's the whole sequence I'm planning. Critiques welcome:
Depending on how close to shitty weather I'm pushing it, I may do step 1 in stages (belly, then interior, then exterior) according to time available to get top coats on. I'll be spraying in an unheated portable garage that has to come down before heavy snow falls (usually sometime in November). Weather should be excellent for painting until then but I have a lot of work to do yet. |
bbrock |
Sep 7 2018, 03:07 PM
Just bought paint for my sons 944 and had the paint shop whom I have known for years help determine how much paint. Went base 2 qts, clear 1gallon , sealer 1qt, allot glass on a 944 but that is a point of reference.. Cost 350 all ppg shopline. Are you doing a complete inside/out respray with that or just exterior? Man! I wish I could get shopline (my local supplier can't get it). I spent over $300 just for a gallon of PPG primer!!! I think top of the line is probably good for a rookie like me though. I've heard Deltron is forgiving. |
Cairo94507 |
Sep 7 2018, 03:13 PM
Michael Group: Members Posts: 9,772 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
mb911 |
Sep 7 2018, 04:10 PM
Just bought paint for my sons 944 and had the paint shop whom I have known for years help determine how much paint. Went base 2 qts, clear 1gallon , sealer 1qt, allot glass on a 944 but that is a point of reference.. Cost 350 all ppg shopline. Are you doing a complete inside/out respray with that or just exterior? Man! I wish I could get shopline (my local supplier can't get it). I spent over $300 just for a gallon of PPG primer!!! I think top of the line is probably good for a rookie like me though. I've heard Deltron is forgiving. Just exterior and jambs.. The 2 qts produce 4 total with reducer so gallon mixed.. |
bbrock |
Oct 4 2018, 06:36 PM
I stopped by my paint supplier today to get some estimates. A 1 gal. kit of Deltron line base/clear will cost me $1,265 vs a half gallon kit of base/clear plus half gallon of Omni single-stage would be ~$919 (~$350 savings). That's pretty good incentive to stick with single-stage for interiors. I will worry about the exterior later since I won't be spraying that until next Spring.
Next question is, how much single-stage? @Andyrew said "probably" 1 quart would be enough. I'd like some margin of safety. Each additional quart of single-stage will run me $75 so I'm tempted to just get 2 quarts which will provide 3 quarts of sprayable product. But I can buy it in 8 oz. increments so the more I can dial this in to have extra, but not too much extra, the more $$ I can save. Thoughts? |
Andyrew |
Oct 5 2018, 12:45 AM
1qt would be fine. But an extra quart would be helpful in the future... You can just buy the extra quart of paint and not buy the extra reducer or hardner.. they have the shortest shelf life anyways.
defianty |
Oct 5 2018, 02:33 AM
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
Incidentally the way you're planning to paint your car Brent is how mine is being done. Base/lacquer on the outside and single stage in the trunks etc.
I'm going to see my car tomorrow to catch up on progress. If you like I'll speak with the guy about paint quantities and get back to you. I warn you now my findings will be in litres though (IMG:style_emoticons/default/laugh.gif) |
Oct 5 2018, 05:20 AM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
We usually do single stage on the interior, trunks, engine compartment, wheel wells and underside. The interior gets covered in soundproofing and carpet, etc. just no need to spend for top dollar paint. Same with the other areas. It has to look good but doesn’t have to be a show finish. It also touches up easier.
It’s funny that on a 914, we paint the interior body color and then take great pains to cover all the color with carpet, pads, vinyl and tape. |
bbrock |
Oct 5 2018, 07:56 AM
1qt would be fine. But an extra quart would be helpful in the future... You can just buy the extra quart of paint and not buy the extra reducer or hardner.. they have the shortest shelf life anyways. Good idea. Unfortunately the mini amount of reducer I can buy is 1 gal. and at 4:1:1 mix ratios, I'll have enough for 4 gallons of color! My local shops says they've tried to get quarts but haven't been able to. Would be nice if they'd just split a gallon themselves but they didn't offer that. Incidentally the way you're planning to paint your car Brent is how mine is being done. Base/lacquer on the outside and single stage in the trunks etc. I'm going to see my car tomorrow to catch up on progress. If you like I'll speak with the guy about paint quantities and get back to you. I warn you now my findings will be in litres though (IMG:style_emoticons/default/laugh.gif) That would be great! Don't get me started on our medieval measurement system. As a scientist, it drives me nuts. Why we insist on clinging to this POS way of measuring things is beyond me. (IMG:style_emoticons/default/blowup.gif) |
defianty |
Oct 6 2018, 04:45 AM
So... had a chat with my painter this morning and he reckons he'll buy three litres of base coat for the exterior. Thinned down to paint, that will give him six litres.
Hope that helps Brent. |
Oct 6 2018, 05:36 AM
Pros usually use 3 quarts. diy guys usually use 1 gallon to allow for mistakes.
mb911 |
Oct 6 2018, 05:59 AM
Pros usually use 3 quarts. diy guys usually use 1 gallon to allow for mistakes. That is true but also remember if you getting a color that there are lots of alternates for the same paint code buy extra.. If you ever have to repaint an area you will be happy you did.. Also remember to get the preferred primers and sealers color based on the final color.. This will help maintain a nice consistency in color.. Silvers are especially prone to this thats why you see so may car's that are silver have odd looking panels when repaired m |
Oct 6 2018, 06:38 AM
Pros usually use 3 quarts. diy guys usually use 1 gallon to allow for mistakes. That is true but also remember if you getting a color that there are lots of alternates for the same paint code buy extra.. If you ever have to repaint an area you will be happy you did.. Also remember to get the preferred primers and sealers color based on the final color.. This will help maintain a nice consistency in color.. Silvers are especially prone to this thats why you see so may car's that are silver have odd looking panels when repaired m (IMG:style_emoticons/default/agree.gif) primer color can change the final look of the paint by a lot. Red or yellow over white primer looks completely different than when it’s sprayed on grey. I’m not a painter but I’ve been told metallics are hard to match because of the way particles lay down. If a door is painted on a table, the metallic will look different than if it’s painted vertical on a car. |
mb911 |
Oct 6 2018, 07:01 AM
Pros usually use 3 quarts. diy guys usually use 1 gallon to allow for mistakes. That is true but also remember if you getting a color that there are lots of alternates for the same paint code buy extra.. If you ever have to repaint an area you will be happy you did.. Also remember to get the preferred primers and sealers color based on the final color.. This will help maintain a nice consistency in color.. Silvers are especially prone to this thats why you see so may car's that are silver have odd looking panels when repaired m (IMG:style_emoticons/default/agree.gif) primer color can change the final look of the paint by a lot. Red or yellow over white primer looks completely different than when it’s sprayed on grey. I’m not a painter but I’ve been told metallics are hard to match because of the way particles lay down. If a door is painted on a table, the metallic will look different than if it’s painted vertical on a car. Yes 100% right. |
bbrock |
Oct 6 2018, 09:02 AM
So... had a chat with my painter this morning and he reckons he'll buy three litres of base coat for the exterior. Thinned down to paint, that will give him six litres. Hope that helps Brent. Thanks Stephen. 3 litres of base would make about 1.5 gallons of sprayable mix in the stuff I'm using. Did he happen to mention how much single-stage for the interiors he will shoot? That's the number most important to me right now. Spraying exterior will have to wait until the winter snows thaw and warm weather returns. (IMG:style_emoticons/default/beerchug.gif) |
bbrock |
Oct 6 2018, 09:10 AM
It’s funny that on a 914, we paint the interior body color and then take great pains to cover all the color with carpet, pads, vinyl and tape. I do it for her. She deserves to feel pretty (IMG:style_emoticons/default/smlove2.gif) Pros usually use 3 quarts. diy guys usually use 1 gallon to allow for mistakes. Whole car or just exterior? |
Lo-Fi Version | Time is now: 20th May 2024 - 11:36 PM |
